11-19-2013, 12:13 AM | #1 |
Bolt it on or sell it?
so a few weeks ago I acquired an interesting setup and have been going back and forth on weather to bolt this setup on and try it out, or just to sell it.
Reasons why i am hesitant to bolt it on are #1. the motor is already a .060 350cid(4 bolt main with a forged steel crank) running atleast 10.5:1 and #2 throttle linkage fitment.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you." '84 chevy half ton short box 2wd, 67,000 actual miles '03 chevy 1500 HD crew cab 4x4 standard box, 6.0L |
11-19-2013, 02:28 AM | #2 |
mini truck racer
Re: Bolt it on or sell it?
I always wanted a set up like this with a Q-jet just to tryout and play with . I think it's cool . If it were mine i would try it on something for sure .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
11-19-2013, 03:15 AM | #3 |
That looks like that turbo setup used on the 301 Pontiac motor...
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-19-2013, 05:42 AM | #4 |
mini truck racer
Similar , but for a sbc . I have also seen some that have a sort of split manifold under the carb with the turbo to one side non intercooled . Pulls through the carb and out the rear of the adaptor . then is compressed . Then pushed through the front of the adapter . The Pontiac deal had the carb on an adapter on the turbo mounted to the driverside if i remember correctly .
11-22-2013, 01:30 AM | #5 |
BigDan it's actually a setup made by A.K. Miller. From what i have read he did alot of salt flats racing. This setup is actually a draw through setup, and puts the carb. up beside or just ahead of the alternator. It was also designed for LP as well as gas. The 2 ports on the carb. hat are for heater hose hook up to keep it from frosting up when running LP.
HotRod If I could get enough flow out of a q-jet I would gladly use one. However I am already running a 750 cfm Quick Fuel carb. and its still NA. q-jets from what I have ever read don't flow much over 700 cfm. I've played with q-jets A LOT over the years and love them for daily drivers, but it just wont work in this case.
11-22-2013, 01:31 AM | #6 |
those are just mock up pictures on a junk motor.
11-22-2013, 11:55 AM | #7 |
Thats pretty cool I have never seen a setup like that before.
11-22-2013, 03:30 PM | #8 |
Put an E85 carb on it and don't worry about the 10.5-1 cr as long as you keep boost moderate.
There are LS guys running 12-1 with 15ish lbs of boost on pump grade E85..
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
