Old 11-23-2013, 04:38 PM   #1
CUSTOM/10
CUSTOM/10's Avatar
WTB Air shut-off damper bushing
I'm missing the bushing circled in red in the picture. Does anyong have one I can but or know where I can get one ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-24-2013, 08:01 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: WTB Air shut-off damper bushing
Anyone?
What has anyone else done ?
Does anyone have a picture of this piece, maybe I could make one.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-24-2013, 08:18 PM   #3
warbucket
warbucket's Avatar
I was looking for one too but ended up making my own. I cut the head off a bolt the same size, welded a washer on the end and then drilled a hole down the center. I reused the plastic nut.
warbucket is offline   Reply With Quote
Old 11-24-2013, 09:31 PM   #4
CUSTOM/10
CUSTOM/10's Avatar
Thanks Warbucket,
But I still am not quit sure what I need. I have a 1/2" hole in the firewall, so I was going to make a bushing 1/2" OD x 1/8" ID with a flange on one end. Slip this into the hole from the cowl side then put the damper into that. Would this work, or am I missing something.
By the assembly manual there's 2 pieces, a bearing & a cap. I don't understand what the cap is for ? Do you think a flanged bushing would work ?
Thanks again !
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-25-2013, 12:03 AM   #5
warbucket
warbucket's Avatar
It looks like the 1/2" hole in the cowl is oversized so you could center the air shut off in the cowl so it will move freely. I snapped mine because they are made of plastic. I used sealer and then tightened it up.
Old 11-25-2013, 08:27 AM   #6
CUSTOM/10
CUSTOM/10's Avatar
I got it now ! You made what I would call a bulk-head fitting. The washer you welded on goes on the cowl / damper side and the nut goes on from inside the cab, and the hole you drilled receives the plastic piece,
I don't have the plastic piece, but here at work we have some small plastic bulk-head fittings that I will modify to make it like your bolt & washer ( But plastic ) with the correct size hole drilled in it to receive the spring loaded pin.
The light bulb just came on !!!! "LOL"
I try and post up a picture when I have on made up.
Thanks, Warbucket
Gary
Gary
72 SWB 4x4
My 72 SWB Build
