DOT air line
Tough cutting 3/8" airline n getting an even cut with the internal white reinforced sleeve. I attempted using a quality metal tubing cutter tool. Not real happy with the results though. Any pointers out there with good results?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
Re: DOT air line
Fresh razor blade?
Re: DOT air line
I have never used a tubing cutter myself I always use a fresh razor blade like scoti suggested. Make sure to place the tube on a good flat surface. Lay the tube flat and center the blade on the tube and press lightly while you rock the blade side to side. Make sure you get a good straight cut. If you have a lot of cuts you could make a jig to help speed things up. But a new blade will cut it like butter
Tot Roddin'
Re: DOT air line
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Re: DOT air line
Very good advice above. Also, if you cut the line and insert into a push-to-connect fitting, make sure to re-cut the line every time you remove and re-insert into a fitting. The fittings put small gouges on the line to grab it and hold in place. It is just a good idea to cut these off, if you remove and re-insert the same line.
