11-26-2013, 09:24 PM | #1 |
A/C heater dash pad vents
Anyone have a good solution for the loose vents on the dash pad,(the vents wont stay in place and must point down? I am) going to do some work on the dash and want to fix the problem while I have it apart. Any one has any ideas that have worked?
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
11-26-2013, 09:43 PM | #2 |
Re: A/C heater dash pad vents
i have allways just used a old folded up napkins... but yea i would like to see other ideals they are a pia.. its kinda like the vent windows too they are noisy i useally use silicone to seal them up or use a quarter to tighten up the vent handle
4x4k30 if trouble was money i would have plenty |
11-26-2013, 10:45 PM | #3 |
Yea I would like to find a more permanent fix if possible, instead of springing for new ones.
11-26-2013, 11:05 PM | #4 |
78K & 79C Jimmys
not sure if a heat gun would work?
i've heated some dash plastics to prevent "brittle" splits slight pressure hold tab out ,till softened or maybe heat from soldering gun,not sure if a lighter would be enough let cool and check?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-26-2013, 11:13 PM | #5 |
18 Till I Die
There is actually a little pad of sticky foam that adds pressure to the sides I believe. I did my 87 camaro with a bit of sticky foam weatherstripping trimmed down. Works very well. Next time I pull my dash pad I will do these as well.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
11-27-2013, 12:03 AM | #6 |
Great idea.
11-26-2013, 11:26 PM | #7 |
I thought it was more of a sticky-backed felt or dense fabric that was on them originally. If you've got it apart, now is a perfect time to experiment with different materials.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
11-27-2013, 01:52 PM | #8 |
I used the fuzzy side of a piece of black velcro..Creates just the right amount of friction to keep them right where you want them...
11-27-2013, 08:01 PM | #9 |
I think I will try that first^^^ Thanks
