12-04-2013, 11:55 AM | #1 |
M & H Wiring Harnesses ?
Do any of the Venders sell M & H Wiring harnesses ? Or do you have to go direct to M & H ?
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
12-04-2013, 05:36 PM | #2 |
One of the First
Re: M & H Wiring Harnesses ?
BROTHERS, thats where I got mine. But, I believe you can go straight to the vendor and buy. I feel they are the best on the market. I had my engine harness modified for a internal regulated ALT and a HEI distributer. No extra charge, but that was 10 yrs ago.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
12-04-2013, 05:56 PM | #3 |
What?
A lot of vendors sell M&H harness's.
M&H is one of only a couple harness builders that make OE spec harness's. You can buy direct from M&H, but you will more than likely save a few bucks by going through one of the vendors for the same thing.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
12-05-2013, 08:19 AM | #4 |
I've heard M&H is about the closest to the original you can get, and that's what I'm looking for. ( Plug & Play ) But I will need some mods done also ie:
Internal reg alt, HEI, Head light relays, Sanderson A/C compressor, and I'd like to go with the ATO fuses. Can these mods be ordered through the venders, or would I have to go directly to M&H ? Gary
12-05-2013, 11:45 AM | #5 | |
12-05-2013, 12:07 PM | #6 |
Hey Jim;
Yeah head light relays is what I was planing, electric rad fans also. I'll probably give both Wes and Darren a call. Thanks Gary
12-05-2013, 06:47 PM | #7 | |
http://www.wiringharness.com/ |
12-05-2013, 09:50 AM | #8 |
2WD Jimmy
Call Wes at http://www.classicheartbeat.com/
He is a knowledgable vendor here and sells both M&H an AAW |
12-05-2013, 10:08 AM | #9 |
Thanks Tom !!
01-15-2014, 01:14 PM | #10 |
both are great units, cost is relative. Why spend lots on money to restore a vehicle and then use an old harness just to watch it burn down around you. Not many old harnesses that have not been butchered for trailors, brake boxes radios etc. safe is better than sorry imo.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-15-2014, 01:22 PM | #11 | |
01-15-2014, 01:44 PM | #12 | |
Hard to beat the quality but they specialize primarily in exact factory reproductions so they are pricey. But , if you are building a Bloomington Gold Corvette nothing else will get you there. |
01-15-2014, 02:01 PM | #13 |
Fitz
That is basically what I did, called M&H went through everything I had in the truck and any mods I need. Then Called Wes at Classic Heartbeat and went through everything with him and got his insight. I ordered it through Wes because the price was a little better, still pricey though. Gary
01-16-2014, 10:04 AM | #14 | |
01-15-2014, 08:24 PM | #15 | ||
"I ain't nobody, dork."
I have an M&H front light harness, and engine harness in my 1972 GMC. Great fit and finish. All came with the proper factory correct connectors and clips. Wrapped with the correct tape, and also had the plastic channels for the wires to fit on the firewall, and behind the radiator. Direct plug and play fit! Money well spent if you ask me, for trouble free wiring.
Got mine from Wes as well. Gary
