Old 12-05-2013, 08:01 PM   #1
allons
E-brake cables
My '72 was a disassembled basket case when I got it. I've done a frame off rebuild but I'm finding many parts that are missing. My E-brake pedal assembly is intact EXCEPT I have no cable running from the pedal assembly to the cables mounted on the frame. Has anybody got an idea where I can find the pedal cable assembly to connect it all? Thanks
allons is offline   Reply With Quote
Old 12-05-2013, 08:17 PM   #2
KMC3420
KMC3420's Avatar
Re: E-brake cables
Most cables I have seen come each individual cable. Subscribing to this one to see if anybody knows where the best place is.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 12-05-2013, 08:19 PM   #3
In The Ten Ring
Re: E-brake cables
I think Rock Auto has those....I think. Anyone else chime in?
Mine are rusted up and stuck! Although I rebuilt my rear drums I didn't solve that problem so I have to take them apart again and either replace the parking brakes or soak them in a break free and um, brake them free.
In The Ten Ring is offline   Reply With Quote
Old 12-05-2013, 09:25 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Re: E-brake cables
Any vendor carries them, autozone might even have them. They are all the same from 69-72 (I am talking about the front cable that runs from the pedal to the drivers side frame rail.)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-05-2013, 09:49 PM   #5
franken
Re: E-brake cables
The best place is probably the nearest auto parts store.
Old 12-05-2013, 09:52 PM   #6
sboris
sboris's Avatar
Re: E-brake cables
In-line tube has quality stuff..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 12-05-2013, 11:00 PM   #7
pritch
pritch's Avatar
Re: E-brake cables
Originally Posted by sboris View Post
in-line tube has quality stuff..
x2 ^^^
http://inlinetube.com/Brake%20Cables...ruck/FT433.htm
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-06-2013, 07:51 AM   #8
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Thumbs down Re: E-brake cables
I dislike the ones they sell now a days. They have a smooth black casing and they don't lock in place like the originals with the spiral metal casing.
What that means is when you press the pedal down, instead of only the cable moving, the casing wants to pull through the clamp so the brakes don't lock on properly. Look at the back of your brake pedal assembly and there is a clamp that locks the cable in place. That's the area that it just slides around in.
I have 2 new cables and I am replacing them with good used ones because of this.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 12-06-2013, 10:44 AM   #9
allons
Re: E-brake cables
You say In-Line tube has them? I've used ILT before and they have solid stuff. If they have the pedal cable, I'm on it!
Old 12-06-2013, 11:34 AM   #10
sboris
sboris's Avatar
Re: E-brake cables
This is where inline comes into play....
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 12-06-2013, 11:50 AM   #11
allons
Re: E-brake cables
Found them on In Line Tube! They come as OE or SST. Also, it's the correct 'braided' design. Thanks for the ILT tip!
Old 12-06-2013, 12:02 PM   #12
1972SUPERSB
1972SUPERSB's Avatar
Re: E-brake cables
I bought an AC delco one. I try to buy all AC delco for my truck. Original parts fit perfect
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
