Old 12-05-2013, 11:09 PM   #1
FlowerForwarder
Heat and noise control in cab
Group-
Which product is better?
FatMat "rattletrap"
Lizardskin Spray on
Or should I use these both?
Please advise
FlowerForwarder is offline   Reply With Quote
Old 12-06-2013, 12:13 AM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Heat and noise control in cab
I have used Fat Mat and will again. Works great tilted at an angle in the doors so water runs off the edge.
NEWFISHER is offline   Reply With Quote
Old 12-06-2013, 12:19 AM   #3
CMFT
CMFT's Avatar
Lizard Skin is a good product. Buy the bed liner sprayer from Harbor Freight and it'll be a quick job. Will take you longer to tape up the cab than it will to spray.
'58 Apache
CMFT is offline   Reply With Quote
Old 12-06-2013, 02:32 AM   #4
OneTwo
If you want the best, go with Second Skin Audio, although you will spend some more coin.
I've never used FatMat, but I've heard mostly good things. My mat of choice is Raamat BXT II, it's the best bang for your buck, in my opinion.
OneTwo is offline   Reply With Quote
Old 12-06-2013, 09:45 AM   #5
boucher racing
boucher racing's Avatar
I have used Lowes Peel-n-Seal. Its a great product at an awesome price point.
A lizard skin spray, with a Peel-n-Seal top would provide max protection.
If it passes the HAMB test, its a good one!
http://www.jalopyjournal.com/forum/s...d.php?t=711889
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 12-06-2013, 05:33 PM   #6
forestb
forestb's Avatar
Are both those products for heat and noise protection?
forestb is offline   Reply With Quote
Old 12-06-2013, 08:57 PM   #7
hotrodder
I USED THE LIZARD SKIN SOUND DEADNER AND HEAT PROTECTION ON MY 63 AND REALLY DIDN'T LIKE THE RESULTS. I'm WITH THE PEAL & SEAL, USED IT ON MY 66 AND IT IS ALOT BETTER. (IN MY OPINION)
hotrodder is offline   Reply With Quote
Old 12-07-2013, 06:22 PM   #8
CMFT
CMFT's Avatar
Curious to hear about your experience with Lizard Skin? We put it in my bro-n-law's 67 camaro and it's been great so far. Sprayed easy and has done its job well.
'58 Apache
Old 12-07-2013, 11:19 AM   #9
cortcomp
cortcomp's Avatar
I used becool peal n stick (lmc, summit, etc) all over the insides of my 66, on both sides of panels (so inside roof skin and inner roof skin, outer door skins and inner door panels, rear cab and rear window panel, etc.
easy enough to apply, and i'm sure double thick it will be quiet
http://67-72chevytrucks.com/vboard/s...=550931&page=5
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 12-07-2013, 11:25 AM   #10
cortcomp
cortcomp's Avatar
More shots end of this page:
http://67-72chevytrucks.com/vboard/s...=550931&page=3
Old 12-07-2013, 12:35 PM   #11
joedoh
joedoh's Avatar
peel and seal from lowes works the same as stuff that costs 10x more.
when sound deadening, it is about lowering the resonant frequency, not making a barrier for sound frequencies. resonant frequency is the frequency of vibration where the input power is the lowest and the vibration is the highest. large flat panels of thin metal have a high resonant frequency, which means that road noise makes the panel vibrate right in the center frequencies of our hearing, 800-5000Hz. you are not hearing the actual road noise, you are hearing the road noise making the panels in your interior vibrate sympathetically. The best way to prevent this is to add mass to the panel and lower its resonant frequency. This does two things, first the new frequency is lower and out of the center of our hearing range and the ear naturally attenuates it, and second the lower frequency requires more input power to have the same output level (you car stereo guys, think about how much bigger woofers and woofer amplifiers have to be than tweeters and tweeter amplifiers to have the same db output).
some guys cover the entire panel, but since its about adding mass you can get 9/10ths of the effect by concentrating on the centers of the panels. This is also why a second layer is a diminishing return, because you have already lowered the resonant frequency with the first layer and achieved a large amount of noise reduction, a second layer will only help very slightly.
asphalt has a lot of mass, so it makes a good noise treatment, peel and seal from the home improvement store is aluminum backed asphalt and is what you need. its likely made in the same factories as fatmat and dynamat, without the fancy label. Make sure you get the pliable foil backing, so you can form it over crevices and gaps in the floor. the stiff aluminum backing is harder to use. use a wooden roller to make sure as much adhesive is in contact with the panel as possible.
also make sure you close off any air holes where sound can get through, that is direct noise transmission through air and firewall (or rust) holes will let in a lot of wind and road noise.
Old 12-07-2013, 01:24 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Great post.
How much would you recommend buying?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 12-07-2013, 01:34 PM   #13
Rich 5150 69
Rich 5150 69's Avatar
One other aspect of the heat issue, put a shut off valve on your heater hose, heat still runs thru the core and drifts in to the cab during summer months without it.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-07-2013, 02:54 PM   #14
protrash64
Resistance is Futile
protrash64's Avatar
Peel and seal here too....easy to do and cheap as ....lol!! It's not as large as the high dollar stuff, but comes in a roll. It was easy to make strips across the entire floor. Low buck
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 12-08-2013, 03:04 PM   #15
joedoh
joedoh's Avatar
Originally Posted by LostMy65 View Post
Great post.
its 25 feet long, so at least a roll spread throughout the big flat panels (across the back of the cab, inner and outer door skins, floor pans especially by where the wheels are) will show HUGE improvement. Its so cheap though get a couple rolls and go nuts.
clean the surface really well. use a good flashing tape on the edges so it doesnt peel up in hot weather.
Old 08-22-2015, 12:03 PM   #16
LostMy65
LostMy65's Avatar
My firewall gets pretty warm, is this stuff ok on the firewall?
Old 12-07-2013, 06:17 PM   #17
LostMy65
LostMy65's Avatar
How much peel and seal do you buy?
Old 12-07-2013, 07:24 PM   #18
protrash64
protrash64's Avatar
I bought one roll. Made by U-seal at the Depot, IIRC. It is 6'' by 25'. I didnt do my whole cab. I imagine two rolls would do the floor pretty well.
Old 08-22-2015, 02:12 PM   #19
I used 4 rolls on my 84, but I did a double layer on the floor and firewall, plus I did the back wall of the cab.
I just did my 64 and used around 3 rolls. Again double on all floor and firewall areas. But I was too lazy to pull the tabjk and do behind it yet. I think I got a 1/43 to 1/2 roll left to use in the doors or?? eventually.
I am sold on the stuff too and even in our heat you don't get any tar-like smell
Old 08-22-2015, 04:18 PM   #20
LostMy65
LostMy65's Avatar
Yes, the tar smell was another of my concerns.
Old 08-22-2015, 06:00 PM   #21
pwrbrkpadguy
pwrbrkpadguy's Avatar
Did my entire cab 3 years ago with peel and seal and never had the slightest smell of tar highly recommend.
pwrbrkpadguy is offline   Reply With Quote
Old 08-23-2015, 12:33 AM   #22
focusedontheprize
focusedontheprize's Avatar
Echoing this comment. I did my entire cab and have had the truck sit in the direct 100 degree sun before and never had the faintest smell of tar.
focusedontheprize is offline   Reply With Quote
Old 12-07-2013, 10:51 PM   #23
theastronaut
theastronaut's Avatar
We've used Lizard Skin in two trucks so far and both had major improvements. We use peel and seal inside the doors where it's hard to spray Lizard Skin.
theastronaut is offline   Reply With Quote
Old 12-08-2013, 01:23 PM   #24
hotrodder
It may just be me , I had used Dynamat in my streetrod builds and muscle cars, and it seemed to work out better. I tried the Lizard skin products for ease of covering the back of the cab and getting down into the cab corners. Maybe just the difference in the type of vehicle. I'm sure Lizard Skin is a good product, not knocking it or anything.
Old 12-08-2013, 05:37 PM   #25
BigDan3131
BigDan3131's Avatar
For us it depends on the owners budget. If its a complete restoration we usually spray it with Rhino because it can go anywhere the gun can be aimed. Other times its Dynatron Rubberized Undercoating 4 coats inside the cab and 4 coats under the cab and if that's not enough we cover it in Dynamat too. The last one is just the Dynamat or the Eastwood version covering everything.
As far as how much you need...if your cab is stripped bare just get a piece of thin cardboard and cut it to the size that the Dynamat comes in and just lay it out in the cab and mark each space it covers.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
