Need help steering shaft repair
I am redoing my steering column and noticed that the rubber boot on the steering shaft [the rubber boot that holds grease in the slip joint] has failed and the slip joint is worn. I want to know if I should cut the shaft and replace the the slip joint with a 3/4 36 spline x 3/4 dd coupler or does a universal joint need to be installed. I will be drilling the shear pins out of the shaft so i will have a slip point. Any pics of modified shafts would be great. Thanks
1971 c 10 manual steering
Fuzzy |
#2 | |
The Older Generation
Re: Need help steering shaft repair
If I were you I would just find a good stock replacement one... LockDoc
ttt
Fuzzy |
Well some time has gone by and I have removed and body worked the shifter bowl to make it smooth and got the steering column stripped and painted and it is looking good. I did pick up a u joint that is a direct fit and looks good to. Next I sent the slip shaft with my buddy to mill it dd all the way so I can cut it to the proper length. Here is a few pics
Fuzzy |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Looks nice, should work real nice
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
Thanks Dale the old joint had lots of play and I did not like the grease running out of the boot on my fenderwells
Fuzzy |
If you replace the rag joint with a new one the steering should feel nice and tight. Some people replace the rag with a u joint as well but in my opinion that lets to much vibration to be felt at the steering wheel.
How do people hook up the second u joint instead of rag joint? Does it take out more play than a new rag joint?
Currently Blazerless
Here's what I use on my trucks, early to mid 90s Jeep Cherokee steering shafts, it's almost a bolt in. You will have to heat and collapse the shaft just a little and on the columns shaft you will need to grind or file a very small notch to clear the Jeeps pinch bolt. The Jeeps shaft has a built in vibration damper and I've found this setup really helps firm up the Chevys steering. Practically a bolt in for around 30 bucks from a salvage yard.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C Last edited by BLAZERMAN; 05-11-2014 at 11:12 PM. |
Another
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
One more
Wow! Great information! Thanks!
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member). |
Does the universal joint slide all the way on column end until bottoms out or until flush with inside hole? Hopefully that makes sense. Lol
Digging up an old bone but very appropriate to my question. Blazerman's photos give reference. Jeep splines are 3/4 -36? and the other is 3/4 DD? Like Borgeson unit but price is a bit steep.
Leadbelly |
#15 |
I believe to. I have an XJ shaft on my Blazer and C10. Around here, they are about $6 from the yards. Most of the time the rubber at the top is worn and sloppy, so I weld it. Amazon sells new shafts for $99 last I saw. They are on most square body Cherokees, not the Grand Cherokee. 80s- early 90s
I've probably used or sold 20 of them.
'68 C10 SWB '85 K30 Blazer |
#16 |
Just wanted to say thanks for the info. This is exactly what I was looking for. Best 10$ spent so far.
Posted via Mobile Device |
#17 |
![]() Join Date: Apr 2013
Does the Jeep steering shaft mod only work for manual steering boxes
1972 K10 SWB wife's driver 1967 Pontiac GTO Big Bird - 1972 Longhorn K30 http://67-72chevytrucks.com/vboard/s...d.php?t=753294 |
#18 |
My guess, top yeah, double "D" and 3/4". As far as steering box do not know the spline count so no idea.
Leadbelly |
#19 |
I got the steering shaft but it does not work for a 72 4x4 with power steering. I thought this worked for all 67-72. If so wondering what I might be missing.
#20 |
How many splines on your power steering box?
1968 LWB C20 / AC / Wood Bed |
