Old 12-11-2013, 06:07 PM   #1
eighteenninetytwo
Painting wheels white.
Does anyone know the official white color of the white tops on the blazers? I guess it's sort of pure brilliant white???
How do I make sure it's s a close as possible if I'm doing it with a can? ALSO and importantly - are there any tips in terms of painting pre-primed wheels to get the best finish. I will of course remove grease and dirt dust etc, but I've never done any auto finish spraying before. Tips would be great.
eighteenninetytwo is offline   Reply With Quote
Old 12-11-2013, 08:33 PM   #2
E.D.75GMC
E.D.75GMC's Avatar
Re: Painting wheels white.
1. Sanded/wire brush to remove old paint and rust.
2. Used POR-15 on the outer lip, around the valve stem, and where the center parts are riveted to the outer part of the rim.
3. Primed and painted GMC "pure white" from a spray can
4. Gloss clear coat
E.D.75GMC is offline   Reply With Quote
Old 12-11-2013, 08:39 PM   #3
eighteenninetytwo
Do I need POR-15 if the wheel is new and pre primed??
Old 12-12-2013, 09:09 AM   #4
68Timber
I know the pieces fit
68Timber's Avatar
Not if they're new/in primer. Just scuff them up well so the paint will stick.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-13-2013, 12:59 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
had a flat late summer had to get new rubber
Not the right white but I just used "tremclad"rust paint
I've heard it called frost white?
I'd throw them in the back of the truck windows closed,in full sun dry/hard in no time!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
