Rocker replacement- will these parts cover everything I need?
I'm getting around to doing the cab sheet metal replacements, and I'm trying to get a list of what I need. From what I've researched on here, top banana is the way to go. Will this cover everything I need? The passenger side isn't anywhere near as bad, but I figure I'll have the parts if I need them. I do need to do the support braces for the driver's side if that factors in.
The rust on the floor is only what can be seen in the pictures, but should I order that part of the floor too? http://www.topbananaparts.com/cab-repair-kit.html Here is the nasty: ![]() ![]() ![]() ![]() Thanks guys.
68 SWB 5.3 turbo build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578220 |
Re: Rocker replacement- will these parts cover everything I need?
I am in the middle of finishing up this exact project on my truck and also needed the toe kick patch panels, front floor patch and possibly front floor section.
Ahh, I thought those were the kick panels in that kit. Looks like I'll just piece it together. Also should just buy the floor piece too.
Will these two pieces cover the rocker area that's rusted out? Inner? http://www.topbananaparts.com/driver...-panel-10.html Outer? http://www.topbananaparts.com/driver...-exterior.html
http://67-72chevytrucks.com/vboard/s...d.php?t=607099
You can see the repair panels I used in this thread. Inner rocker and outer floor repair panel in one piece... Full length |
Safety reminder: You should remove the fuel tank and lines from the cab before doing the welding.
cheers JohnG |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 12-12-2013 at 05:08 AM. |
"..And for the professional purists ...I use butt joints on cab corners and visible body panels."
Lol....glad I could help. (I lap weld.... But am by no means a professional) |
That was a repair panel from triplus
Airbrushguy said he found a set... He could tell you |
#12 | |
#13 | |
cheers JohnG |
![]() Join Date: Jul 2013
The kit from Top Banana includes the most common replaced parts. The inside kick panel can be bought separately but most people just fab up a piece to fit where it is rusted. The rust on your cab looks pretty normal.
I'm currently waiting on Santa's big brown truck to deliver my kit from Top Banana.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#15 | |
cheers to all JohnG |
#16 |
Awesome, this thread has been super helpful!
Bear with me here, I'm new at this... So this piece that I circled will work as the inner rocker, then it's up to me to fill in the floor that's rusted and kick panels where they meet the floor? Also, I obviously need the outer rocker panel right above it in the picture. ![]()
#17 |
Yep... thats inner rocker and edge outer edge of floor you have circled
#18 |
The panel I used was one piece..
edit: those are one piece. lol right and left... sorry |
#19 |
Not to keep jumpin in on your thread... I would get everything in that pic if I was to do it again. I ended up making lower pillar pieces. That would save lots of time. Yours are likely shot too.
#20 |
Is that the piece right below the kick vents in the cab?
Can't thank you enough for the guide to doing these, it's incredibly helpful.
#21 |
No.. the pillars are behind your fenders. Kick panels are the vertical panels that meet the floor... where the vent is installed
#22 |
Kickpanel in first pic.. dragged with filler waiting to be sanded. (made my own repair pieces with metal brake) Front pillar visible under the door hinge..whats left of the bottom of it. Its outside the inner rocker
