Cluster King
![]() Join Date: Nov 2012
1964 - 1966 gauge cluster restoration
I can build these to order.
The photos are an example of the quality of work that goes into each one I build. A complete cluster with light harness as shown is $300.00. The build includes: Bead blasting and painting all tin work. Clean, test and reface gauges as well as paint the needles. Speedometers can be reset and set to mileage of choice for an additional charge. Wiring harness inspected, cleaned and re-taped. New bulbs installed (with wiring harness only). I will send new bulbs with cluster that does not have a harness. Custom bezel paint, polished or chrome bezels are an additional charge. An aftermarket 5,000 RPM tach kit can be added for $220.00. I have a high work load so these will take time to build. I will deduct $30.00 for a core cluster. Thank you for looking, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C Last edited by TBONE1964; 12-14-2013 at 04:49 PM. |
![]() Join Date: Sep 2011
Re: 1964 - 1966 gauge cluster restoration
Very nice job. A lot of labor and time to get them to look this nice. Good luck on your sale.
Cluster King
Thank you Paul, I appreciate the comment.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
![]() Join Date: Aug 2004
Do you just do 60-66 right now? I have a 69 Chevelle tach and clock cluster I need done also.
65' Chevy C-10 Shortbox |
Cluster King
PM sent
I am in, don't mind paying for a skill I don't have.... Next step?
Ben |
#7 | |
Cluster King
Cluster King
ttt
Ask me about restoring your own cluster. Thank you for looking, Tom
Tom did my cluster and it came out GREAT!
Cluster King
I am glad you are happy with it Ben. Thank you for the business.
Take care, Tom
Please PM me your contact details at your convenience.
I have a 64 cluster that I'd like to have restored. Thx |
#12 | |
Cluster King
PM sent Thank you, Tom
![]() Join Date: Sep 2013
Hi
I have a 62 C10 cluster I would like to get restored. It is not in bad shape, but since I am re-doing everything else it makes sense to do this as well. I know your title says 64-66 but can you do a 62? Thanks |
#14 | |
Cluster King
If you open this link and go to page #2 and post #34 you will see one from a 1960 I did for a customer. I can restore your cluster but I am a little back logged with work currently and getting ready to move my business from Michigan to Oregon. What is your time frame for completion. Please feel free to PM me with any questions and a quote for the restoration. Thank you, Tom
#15 |
Hello t-bone I just wanted to follow up with you to see if the testers worked out for you?
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
#16 | |
Cluster King
The testers work great and thank you again. Looks like there are some other people out there looking for a full gauge lens. Someone needs to reproduce these, they would sell. Take care, Tom
#17 |
will the oem gauges work with new style sensors?
thanks! larry |
#18 |
Cluster King
Hi Larry,
Yes, the oem gauges will work as long as you do the following: For the oil pressure, it is just a hard line into an oil pressure port on the engine just like the original. For the temp gauge, you will have to use the correct temp sending unit for the gauge. If you have a 65 pick up, then you would need a temp sender for a 65 pick up. You may have to use an adapter or drill and tap a hole for the temp sender to pipe thread. I think it is 1/2 NPT but not 100% sure. It may be 3/8 NPT. For the fuel gauge, again it will match the sending unit. If you are using a later model tank (in between the frame) with a 0-90 ohm sweep on the sending unit, then the gauge will need to match. Prior to 1965, I believe the ohm range was 0-30. I am not sure if this applied to pick ups. I can do more research on this if needed. For the amp gauge, it will wire into the system just as factory. 1 side of the gauge will be from battery positive and the other side with be from alternator output. Most GM gauges worked on the same principal from 1965 to the late 90's. Hope this helps. Let me know if you have any questions. Have a good holiday, Take care, Tom
#19 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Have you considered offering an option to
replace the Ammeter with a Voltmeter as part of your Restoration Services?
#20 | |
Cluster King
I did this for one customer and he liked the result. It uses a volt gauge from a 73 + As you can see from the photos, I incorporated the tins from both old and new and used the face from a 64-66 cluster amp gauge. I will have to see if I can find photos of it finished. it does have a stock appearance. Lots of work and fabrication.
#21 |
![]() Join Date: Feb 2003
I will take one for my 1965 v8 auto... dave
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
#22 |
Cluster King
Hi Dave,
I will send you a PM soon. Thank you, Tom
#23 |
Can you do me any good on a 1963 GMC Dash?
Thanks Jay |
#24 |
Thanks, yeah, I have a core and in pretty good shape I think anyway.
Should I drop you an email? Thanks Jay |
#25 | |
Cluster King
Thank you, Tom
