12-15-2013, 01:09 AM | #1 |
Srandard trans linkage
I'm doing a auto to std transmission conversion, I was given the clutch petal & linkage out of a 65 with a Saginaw 3 spd, I have a 71, does any body know if this will make up to my Saginaw 3 spd?
There is a piece that is under the hood that bolts up between the frame and the bell housing, maybe; that piece was already off the truck, I would post a pic of the piece but I can't get them to upload to the forum. any help would be appreciated. |
12-15-2013, 02:02 AM | #2 |
Re: Srandard trans linkage
I've done some more looking It's the Z bar mount for a L6 the frame side I'm talking about I really need to see a picture of a 6 cyl clutch linkage to see how to install what I have, the doner truck was a L6 mine is too so the motor side bracket should work but I need to see how it all goes together.
12-15-2013, 02:19 AM | #3 |
i hop this will help
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
12-15-2013, 03:12 AM | #4 |
It does by helping me to know how to orientate the linkage, thank you I really didn't know how to ask for what I needed.
That Z-bar, is it mounted to a hole in your frame or is there a bracket in there somewhere; I have the Z bar with a mount on the motor side on the other side theirs a swivel joint that mounts to something, I found no bracket on the doner truck and the Z bar was already off the truck when I got there. |
12-15-2013, 10:09 AM | #5 |
Not sure if it will help you or not but I will post anyways. I took some reference pics of my buddy's truck so I can reinstall the column shift linkages and kinda got some of the zbar setup in there as well. HTH
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
12-15-2013, 01:10 PM | #6 |
Yes that's it Russgoodman that's it exactly, I didn't know which way was right side up or for sure where the linkage exited the cab. Thanks to both of ya'll for the help.
