Old 12-15-2013, 10:47 PM   #1
AB6DO
Fender mount gas filler
Been looking up past threads for ideas on mounting a gas filler for my under bed mounted 20 gallon Mustang tank. I found a picture of Kid's great truck. His fender mounted gas filler without the usual gas filler door looks GREAT!
Does any one know what filler neck and cap was used?
AB6DO is offline   Reply With Quote
Old 12-16-2013, 12:51 AM   #2
mr48chev
mr48chev's Avatar
Re: Fender mount gas filler
Not exactly sure who's truck you are asking about. There are plenty of options for what you are thinking of though.
My ongoing truck projects:
Old 12-16-2013, 01:33 AM   #3
OrrieG
OrrieG's Avatar
photo or link to what you were looking at?
Old 12-16-2013, 02:36 AM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
You will need some bends but the 1TN from Tanks Inc is the neck, TC is the cap and either a GR2 or GR4 for the grommet. I think your 20 gallon tank has the filler to far back to make that work. If it was a 16 or 18 with the filler on top is may work correctly but the 20 is pretty much a back fill only.
Old 12-16-2013, 02:48 PM   #5
AB6DO
http://s308.photobucket.com/user/51g...00144.jpg.html
This is a link to a photo of Kid's pickup showing his fender mounted filler. This is what I want to use on my 48 5 window using a 1969 Mustang 20 gallon tank. I have removed the center fill spout and welded on a side fill neck filler tube. This tank fits perfect.
Old 12-16-2013, 04:13 PM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
Then you just need the parts above with either a steel elbow or a rubber elbow
Old 12-16-2013, 08:44 PM   #7
av8tr33337
av8tr33337's Avatar
If that's the same truck I'm thinking of, I was under the impression he used the stock filler neck and grommet from the old truck and used elbows etc to make it work.
av8tr33337
AKA Bartman Email av8tr33337@yahoo.com
Bartman's Ad-S10 Chassis Swap
http://67-72chevytrucks.com/vboard/s...d.php?t=415418
My First Youtube Video
http://www.youtube.com/watch?v=B6hSt...eature=channel
More Pics of the 51 Project
http://s668.photobucket.com/albums/v...hassis%20Swap/
1951 3100 Pickup
av8tr33337 is offline   Reply With Quote
Old 12-17-2013, 01:36 PM   #8
mr48chev
mr48chev's Avatar
I'd say that is exactly what he did. The gromet appears stock and I'd bet dollars to donuts that he at least used some of the stock filler neck. It looks like it came that way rather than being an add on.
Can't help you with the Gray Dan but it sure looks good.
Old 12-17-2013, 03:21 PM   #9
roger55
roger55's Avatar
In case you didn't notice from my pictures, I used the flange that I cut out from the front hole and welded it in the new rear hole.
I cut my patch up front from one my old cab corners that I'm replacing. There's a perfect contour from within the cut-out cab corner.
I used my stock filler neck but had to weld a pretty sharp angled extension on it to make the angles right for reaching my tank from the rear fender.
roger55 is offline   Reply With Quote
Old 12-18-2013, 02:45 AM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by mr48chev View Post
....Can't help you with the Gray Dan but it sure looks good.
Some help you'd be, it's light green! I guess you're a bit color blind, huh?
Kid PM'd me with the color name. I'd post it but I don't know if he wants that done or not.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-16-2013, 10:47 PM   #11
Dan in Pasadena
I NEED to know what color he used! I think I've asked before but never got a definitive answer. Any help?
Old 12-16-2013, 11:51 PM   #12
roger55
roger55's Avatar
Old 12-17-2013, 03:18 PM   #13
mr48chev
mr48chev's Avatar
Aah Roger to the rescue. A great tutorial on how to do it.
Old 12-17-2013, 07:54 PM   #14
_Ogre
_Ogre's Avatar
very nice work roger55
i so wish i had mounted my gas filler up top of the fender instead of in the middle
it looked so natural when i welded it in (sitting a foot off the ground on jack stands)
shop air compressor timer
Old 12-18-2013, 12:21 PM   #15
pgf545
pgf545's Avatar
My plan is to use one of these. We bought a flat one that I think will work but I really haven't gotten to installing it yet.
http://www.haganauto.com/fuel_doors_gas_lid_s/5.htm
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 12-18-2013, 04:52 PM   #16
buggy5872
buggy5872's Avatar
I cut the fuel door and filler neck from a panel truck and welded it into the rear fender. Worked out really well for me. Not sure what year truck the op is working on.
___________________________
1959 Apache Short Fleetside,
1959 Apache NAPCO Long Stepside,
1957 3100 with 59 fleetside bed
1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370
1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF
1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker
Big Bertha Build
buggy5872 is offline   Reply With Quote
