![]() Join Date: Sep 2009
front clip removal
has any one put this on here I looked in the faq section but could not fin anything. going to replace my engine and want to remove front clip. when this is done do you remove the inner fenders also ? this is not a total tear down just replacing the motor. thanks
Re: front clip removal
You don't need to remove clip to swap motor. I always pull the radiator and Hood. The side elbows need to come off to get to the top fender bolts. The lower bolts and radiator core bolts firewall bolts.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
heres how far i went to remove my 350/T10 and to put in a 5.3L/4L60e
I used yours to highlight bolts for full front clip removal. There are also rear lower bolts not in picture. Don't forget the little cover for steering. Nice to work on clean engine compartments.
![]() Join Date: Apr 2009
i never take hoods off in 30 years of being a wrench,,,
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
![]() Join Date: Sep 2006
Remove the 14 bolts as shown in the pic above and just lift the whole thing out of your way. The nice thing about it is being able to clean up the frame and inner fenders and giving them a fresh coat of paint if that is what you want. Also.. While you are unbolting it take notes on how many spacers come out and maybe label them so you know exactly how many to put back in certain places.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
thanks guys. the reason I want to pull the front clip is I wasn't to pull my tranny with it. the top bolts on the 2004r are hard to get to and I want to change my flexplate also
I'm going to do the same thing in the spring. Mostly to clean it all up but my rear main leaks real bad.
66 shorty ![]() |
i just take the radiator out . i have never taken the hood off either.
60-66 Nut
I've pulled many engine and trans together with just removing the hood and radiator. Unless you just want to pull the entire front clip, that's up to you, but it isn't necessary for what you are wanting to do.
![]() Join Date: May 2007
pulling the clip is fast and easy, my core support bolts were stuck but a jack popped em.
I suppose I went too far? lots of elbow room though.
http://s1299.photobucket.com/user/jb...23904108567829 |
