Behind the seat speaker question
Ok,finally decided i needed more than just the 1 center dash speaker to listen to some tunes(mostly country of course)
I had and Audio shop up the street from me make a custom box to fit the 6x9's in the corner. It worked out great.
84 Chevy Stepside, 350, TH350, 268h Comp cam, Hooker headers, MSD Pro Billet, Edelbrock Performer manifold and 1604 carb, 40 Series Flowmasters dumped, and Western Chassis 3/5 drop w/ c notch. New 3:73 Eaton Posi |
"The dude abides"
They won't fit? I have Pioneer 6X9's in truck boxes back behind my seat and the seat is pushed all the way back. (82 Chevy Scottsdale K10 LB)
The boxes are a wedge shape and I just have them sitting so that the 6 X 9 is pointing straight up. I was afraid that this might be too much treble and make my ears bleed, but the top part of the back of the seat goes back enough to where it blocks a lot of the sound. Works out pretty well and puts out enough to hear them going down the highway with all 3 windows open.
RockMan 1993 Chevy Silverado C3500 1 ton dually 1994 Honda Civic 1969 Oldsmobile Cutlass S 1953 IH Farmall Super M New to the fleet: 1992 Subaru Loyal |
Rockman..how bout a picture?
Hey Rockman..can you take a picture of how your speakers are sitting behind the seat? Maybe the boxes i have are just bigger than yours.
i had no problem with mine but i also made my speaker boxes and i fit two 6x9 3 ways behind the seat no problem
I need a 454 4 barrel and dad wont let me get one |
yeller
Did GM ever offer 6X9 speakers in the rear of its PU trucks as an option?
I would love to find a set of those if they exist. ...Jeff |
Professional Grade
I would just build my own box... Much cheaper...
Does anyone know the sizes of the door speakers, rear speakers and the dash speaker? If your truck didn't come stock with a dash speaker (either that or mine just doesn't work, I don't have a stock deck, some junky Panasonic crap...), is there mounting gear under the dash for a speaker? I want to replace all of the speakers in my truck as these ones just can't take loud music without distorting right away. The door speakers I have are behind little "cups" that screw onto my door...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Insert Witty Text Here
A friend of mine has mounted some large 6X9 speakers in the cab corners using the original 4X10 mounts. What you have to do is to switch sides, left to right and right to left. It changes the mounting angle of the speakers so that the larger magnets fit in the corners.
You can also try to find some aftermarket 6X9 corner mounts. Several people here have them. I was not able to locate any of them new, and it took me almost a year to find a set in a junkyard truck. I have some pics of mine around here somewhere if you need to see what they look like. Slonaker |
Somebody (not sure who), make an adapter kit to go from a 4x10 to a 6x9, I was accually looking at this today at the parts store. Just check around, I'm sure you will find it.
-90 454ss http://www.imagestation.com/album/?id=4289115843 -04 TRX450R -77 c-10 http://www.imagestation.com/album/?id=4290506213 SOLD -82 c-10 SOLD -02 CRF450 SOLD |
"The dude abides"
I will see if I can snag a digital camera from work here and take some pics tonight when I get home.
Before the pics are taken, no commenting on how messy behind my seat is! ![]()
#11 | |
I used some 7/16" OSB I found laying around the house and mounted 6x9 to it and mount in the rear cab corners. Works good for me.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
LED King
Actually, the dash speakers are 3 1/2s.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
#14 | |
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
#15 |
I got a set of plastic 6x9 speaker housing made for retro fitting 6x9's in the corners of trucks. Got them at a local audio place for cheap and they work fine. One day, I'll get one of those, fancy looking, kick panel mounted speaker thingies like Lohrtbt has..
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
#16 |
"The dude abides"
Finally! Pics!
Here is how my speakers fit behind the seat.
#17 |
Can your seat go all the way back w/those back there?
#18 |
84stepper.......which one? audio plus or toys with noise?
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
#19 |
"The dude abides"
The seat will not go back anymore. This was set before anything was even put behind the seat. So it is either all the way back or else the rails on the seat are not working properly. I would say that it is all the way back though because the top part of the back is almost touching the rear of the cab. If it went back any further, the rear of the cab would start pushing the seat back forward.
I am a hair over 6 foot and I sit very comfortably in the truck.
#20 |
You must be 6' tall with short legs! I would never even get in the seat with those. Your lucky. Hey prerunner...Audio Plus.
#21 |
speaker question
That is how i thought you meant they were sitting,just makeing sure. Those look like the same boxes i have. I would have to be 5 feet tall to sit those in my truck like that. When im in the truck,if i put a 44 oz. cup like you get from the Speedway gas station for a fountain drink between my legs,its rubbing the steering wheel. Maybe my seat is just messed up,i dont know.
#22 |
hometown heroes!
Hey, at least your seat folds down!! Mine is a car seat and doesn't fold. I had to stuff my box back there. Its one box with two speakers in it. $20 at Wally World. Works pretty good, except the speakers face forward and the rear of the seat muffles the sound when the seat is all the way back. (Which it needs to be, cause I'm almost 6'2".:p ) I keep it one or two clicks forward and it was uncomfortable at first, but I got used to it.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th... ![]() Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee "Never give up ground you've already taken." -Unknown |
#23 |
Stylin
i hear ya navy ive got the same box but i bought some different speakers and installed them im 6'1 i got used to it after a month but when i jump into mom 01 quad cab dodge and skoot the seat back man i miss that,im thinking of doin some wood work and filling the cab corners again. ive got a 600 watt amp behind the seat 2, no obstructions from that with the seat back.
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
#24 |
Rollin' Member
i have a bunch of speaker behind the seat now. 2 6X9's and 2 10s.
i'll snap a pic this week.
:: 1977 C10 cheyenne :: :: 1973 new yorker brougham :: for sale - $1,500 lofat productions |
