Old 12-18-2013, 11:09 AM   #1
moregrip
moregrip's Avatar
87 cab with 73 front end???
Does anyone see any issues with running 87 cab with a 73 front end? will the older hood mount with no issues? I have a 73 frame, and 73 front end, and 73 cab for that matter. Would like to use an 87 cab (in better condition) on this truck. need help from someone smarter than I.
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 12-18-2013, 11:18 AM   #2
Jonboy
Slots go on anything!
Re: 87 cab with 73 front end???
It will work fine. The '73 hood bolts to the fenders, so that is not an issue. The wiper stands are different, and you will probably want to cover the holes where the hood hinges were. I think I would use the wiring from the '87 cab, but that is just me.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 12-18-2013, 11:23 AM   #3
moregrip
moregrip's Avatar
first, thank you.
I know with the 73 hood it extends to cover the wipers where as the newer hood has a fixed piece. Will that cause me issues? or will I just have to transfer the parts from my 73?
Old 12-18-2013, 11:26 AM   #4
Jonboy
You will pitch the metal cowl grille in the '87 cab. Transfer your '73 wiper stands over, and you should be good. Now is also a good time to replace your body mounts .
Old 12-18-2013, 11:29 AM   #5
moregrip
moregrip's Avatar
I have new body mounts waiting to do their job!
Old 12-19-2013, 11:12 AM   #6
nekkidhillbilly
id ebay it before id pitch
nekkidhillbilly is offline   Reply With Quote
Old 12-19-2013, 05:13 PM   #7
xrcr
put a 84 with a 76 front. No real issues, you'll have cowl holes where you don't use them and hinge holes but that's just an aesthetics thing or a rain thing. My truck was turned into an egg hauler so it wont see any weather.Name:  painted.jpg
xrcr is offline   Reply With Quote
Old 12-19-2013, 05:40 PM   #8
mrolds88
Might want to transfer the outer sections of the cowl too. Not only would you cover the hinge holes, but it will allow you to use the factory bolt on stops that hold the back of the hood when its shut.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-18-2013, 08:50 PM   #9
79Betty
79Betty's Avatar
Hope you don't have the same problem i did. New mounts and all is well. Put on 3" body lift now nothing lines up... :shrugs:
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 12-19-2013, 08:37 PM   #10
nekkidhillbilly
its on here how to make the stops and the holes you can just weld up
