Old 12-18-2013, 01:35 PM   #1
valentini
Tremec in C-10, k-15?
Has anyone out there put a Tremec TKO into a 67-72 pickup? If so, can you tell me if you have a bench seat and if you are using the default shifter mount position?
Thank You,
valentini is offline   Reply With Quote
Old 12-18-2013, 08:22 PM   #2
70chev383
70chev383's Avatar
Re: Tremec in C-10, k-15?
I used the mid shift on and I have lots of room
70chev383 is offline   Reply With Quote
Old 12-18-2013, 10:26 PM   #3
BossHogg69
motor exploder
BossHogg69's Avatar
I did it with a bench seat, and the rear shifter position with the shifter mount flipped around. Used a Hurst stick for a bench seat car.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 12-20-2013, 08:31 PM   #4
valentini
Adam, (bosshogg69)
In the pic can you tell me if that is in gear? How is the reach when seated? Can you sit comfortably against the back of the seat and slam through the gears? (Assuming you are 6' give or take a couple inches?) Also, how much room clearance between the dash when it is in 1st, 3rd, or 5th?
Thanks Again!
Old 12-20-2013, 08:37 PM   #5
valentini
Sounds like the rear position works out fine with modified shifter.
Dan42, I see you hit the dash in 5th. Is this a mid mount position?
70chev383, Can you provide more detail on the Mid position? Does the shifter angle back towards you?
Additional pics are welcome,
Thanks Again!
Valentini
Old 12-19-2013, 12:17 AM   #6
dan42
dan42's Avatar
Buddy buckets, lots of room. No issues. Actually had to tweak shifter a bit because it hit the dash in 5th
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 12-19-2013, 12:52 PM   #7
Lattimer
Lattimer's Avatar
I have one and got it from American Powertrain. They have an offset shifter that fits the rear mount and I was able to clear my bench even with the engine in the L-6 position. Check my build thread for pics.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
