trans range sensor connector, glued in?
Hey folks,
Longtime lurker, first time poster. Gathering bits and pieces for putting a 5.3 into my '66 c-10 My harness came missing the range sensor plugs, and now I see why. Today in my travels amongst the ye olde junque yardes every 4l60e I found had the plugs glued in. What in the heck? I'm new to these late-model rigs, is this common? Thanks |
Re: trans range sensor connector, glued in?
Welcome
Mine were. I was able to wiggle them lose with a little gentle persuasion from a flathead screwdriver. Someone posted though about using a heat gun to loosen up the glue which probably be the best bet. |
yes use a heat gun or hair dryer, all you need is a little heat to loosen the sealant in the connector's, had many over the years at a GM shop, I think GM had tsb on this procedure, also if you need to reuse the switch or connectors, heat before reassembly
1950 Chevy 3100 |
I used some brake cleaner on mine, let it sit a few and pulled out very easy.
Sounds like we have the same problem. I am putting a 6.0 in my 62 and my plug was cut out of the harness as well. I am curious which yards you were looking at in Portland. I too am on the lookout for a decent 4l60e.
#6 | |
the sherwood u-pull-it had an '01 silverado that i took the sensor and plug from. it was put out that morning and the engine was gone by the time i got there. trans fluid looked like red milk so I passed on it. I am beginning to think that looking for a 4l80e is a better bet. Or rebuilding a Gen II "298mm" 4l60e into a compatible "300mm" unit. this is one of the things my old man warned me about when i started talking about the LS swap. it'll be worth it though. Thanks for all the replies y'all. Next time I'll have my trusty heat gun unholstered and at the ready. |
Boosted Member
Removing those connectors is one of the worst parts of an LS swap. haha.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
just about done with the harness modification for stand-alone
since my trans range sensor was cut, i'm having a hard time figuring out which BLK/wht wire goes to which plug. one BLK/wht wire goes to a ground splice pack, and the other goes to blue PCM connector #32, range sensor input A. which one goes to the large plug, and which to the small? Thanks fellas. -doug |
Hey Doug, just checked my harness. Blue 32 goes to the small white plug on my 05 harness.
I used the PNP C1 picture and the cross referenced the circuit numbers/ labels with the ECM pin-outs listed on lt1swap. I am going to use PNP C2 for my backup lights, safety switch. Hope that helps.
thats the info i needed, thanks folks!
Just one more, I swear!
Can I run my back-up lamps straight from the F pin on the large plug, or will it need a relay? Thanks! |
That's the way I have mine wired, no relay since the factory didn't have one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
![]() Join Date: Sep 2005
I had my harness done and they removed that plug my back up light are run off the switch on thevsteering column
#15 |
Don't see why that would not work. I will dig out my multimeter and see what I can come up with.
#16 |
Just did some testing with the multimeter and when I put the transmission in reverse it closes the circuit between pins C and F, so yes you can run the backup lights off that circuit. Don't see why a relay would be needed.
#17 |
here is the drawing i did to make it more clear in my head.
hope it helps.
My Projects- http://67-72chevytrucks.com/vboard/s...d.php?t=557301 Quest for Hot Rod Power Tour 2013. http://67-72chevytrucks.com/vboard/s...d.php?t=543735 my 85 GMC 2wd to 4wd conversion for the wife. |
#18 |
Good to hear. Great info in here fellas.
Thanks once again! |
