Old 12-19-2013, 03:21 AM   #1
kevinr1970
Problems putting newer body on '76 K5
I was wondering if there would be any issues putting a newer ('87+) k5 body on a '76 k5 frame.
This will be a 4x4 body onto a 2wd frame if that makes a difference.
I am aware of the difference in the hump being taller for the 4x4.
I am most concerned with the floor of the '76 going all the way to the front seat before it drops, vs. the '87+ dropping just after the front of the rear seat. Are there differences' in the frame that might interfere with the newer style body?
I plan on running the '76 nose and understand I will have to work on the frame horns to mount the front bumper, but what about the rear bumper?
I plan on running the newer interior; will the newer column have any issues mating to the steering box?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 12-19-2013, 09:10 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Problems putting newer body on '76 K5
CamaroChris is doing something similar here: http://67-72chevytrucks.com/vboard/s...d.php?t=606127
Supposedly the frames are the same but I do not know if any body mounts moved when the rear seat got a footwell in '78.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 12-19-2013, 01:22 PM   #3
kevinr1970
Thanks for the link.
I read that one befroe, but he ended up scrapping the 2wd frame he had because it had issues. He is now converting a 4x4.
2000 Tahoe Limited
