12-21-2013, 02:03 AM | #1 |
Idle problems
Just put a new SMI carb on today and the idle is having problems. I set the idle to around 800, but accelerating past 1500rpms or so will cause the idle to 'stick' at that rpm and not go down until I manually pull on throttle lever to return it to its normal position on the idle screw. When I do that I can hear a metallic clicking, like something is catching, but I cant see anything catching in the linkage. Maybe the primary plate is catching? Seems unlikely though since its a brand new carb from SMI
I would just pull it off but of course I just drove to work...
Josh 72 C10, 350/2004r, Porter Steel Pacs, and 40+ years of leftovers from strange POs... |
12-21-2013, 02:43 AM | #2 |
Re: Idle problems
Whoops.... Nevermind. I guess I must have bumped the fast idle cam out of position when I put the carb on. All fixed now
12-21-2013, 07:25 AM | #3 |
Re: Idle problems
Boy, and I was just going to suggest you probably bumped the fast idle cam out of position when you put the carb on. LOL
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
