Old 12-22-2013, 01:48 PM   #1
DENALI
3100 AD max tire size in rear?
What size/width 19" wheel/tire combo can I get in the rear fenders of a 47-54 3100 without mini tubbing? Thanks
DENALI is offline   Reply With Quote
Old 12-22-2013, 02:01 PM   #2
solidaxel
solidaxel's Avatar
Re: 3100 AD max tire size in rear?
I run 255 75 15 on all my trucks, no tubs, Camaro axle, Monte Carlo, Regal type may be 1" narrower
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 12-22-2013, 02:49 PM   #3
torchlight
torchlight's Avatar
I'm running 15x8 inch wheels in the back and the tires are 255/70r15 and I don't think you could go any wider than that without tubs.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 12-22-2013, 05:21 PM   #4
oldman3
oldman3's Avatar
I'm running a 235/55/17 tire on a 17"X8" rim with a 3-1/2" BS. The rear axle is a 74 nova and is 60" from mounting surface to mounting surface. The bed on these pickups is 50" wide, you have approx. 12" from bed to inside lip of rear fender, for a total of 74". The section width on my tire is 9.5" and I have no rubbing problems. When I was checking on mine the widest section width I could go was 10.4" with only 1/2" clearance to hitting the bed. That tire was a 255/50/17....Jim
oldman3 is offline   Reply With Quote
Old 12-23-2013, 04:40 PM   #5
Old Crow
Old Crow's Avatar
Back in the day I ran 31-11.00x15s on 15x8" rims on the back of my first '54. I loaded the bed down with firewood each winter and never rubbed the inside or the outside.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 01-03-2014, 04:01 AM   #6
MIKEs50Chevy
MIKEs50Chevy's Avatar
I'm running 275/40ZR20 on the rear of my 50 3100. I don't think you could fit any more rubber without tubbing it.
MIKEs50Chevy is offline   Reply With Quote
Old 01-07-2014, 07:19 PM   #7
Firstgenfan
I had to mini tub mine to stuff the 275/40/20's on mine. I'm running a 20x10 wheel.
Firstgenfan is offline   Reply With Quote
Old 01-07-2014, 10:03 PM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
What rear axle are you running, width, and whats your wheel measurements if you dont mind. Thanks
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 11-12-2014, 03:17 PM   #9
MIKEs50Chevy
The rear axle was in the truck when I bought it but I've been told it's probably out of a Chevelle or something similar. I'm running the 275/40ZR20 tires on Ridler 695 20"x8.5 wheels. I hope that helps.
Old 10-05-2014, 08:44 PM   #10
Henney
Looks like the thread died but I'm looking at the same question Stockish had? Any dimensions available for the rear end? How about up front, what's the setup and does everything fit?
Henney is offline   Reply With Quote
Old 10-05-2014, 10:30 PM   #11
mr48chev
mr48chev's Avatar
I've got 255 70 15's on 8 inch rims on mine and would be hard pressed to stick a 1x4 between the tire and bed or fender as clearance is very slim. That's with a mid 70's Nova rear axle.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 10-06-2014, 09:25 PM   #12
Hampshire
Hampshire's Avatar
255/65-16 on 7” wide smoothies from Wheelsmith w/4" backspace. Axle is a 72 Nova.
Hampshire is offline   Reply With Quote
