Old 12-23-2013, 07:01 PM   #1
myyamr7
myyamr7's Avatar
BBC vs SBC engine stands and mounts?
I was searching for some engine stands for the big block I plan to put in my truck over the winter and noticed some vendors only have the right side reproduction, and no listing for a left?
First question is, is the left and right the same stand?
Second question, what is the actual difference with the small block vs big block engine stands? I know in 73 and up, the same mounts worked for both small block and big block without any modifications...so I'm almost certain the small block mounts will at least bolt in and have the same angle? Is there another reason why the SMB stands won't work? Mine is 1971 with the pads, not clamshells.
Mark
71 C10 Cheyenne
12 Aprilia RSV4
myyamr7 is offline   Reply With Quote
Old 12-23-2013, 09:02 PM   #2
68bowtie
68bowtie's Avatar
Re: BBC vs SBC engine stands and mounts?
the big block stands are notched to clear the exhaust. left and right are different. i've seen a thread on here about it a few years back. you may be able to find a set of stands in the for sale section. they normally go for about $75-100 a pair.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Thank you all so far you are angels!!
Old 12-23-2013, 09:31 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can set your big block down on small block stands just fine, but you'll not find an exhaust manifold or header that will clear them. The BB stands have a clearance built into them to allow the exhaust clearance.
The thread 68bowtie is talking about was likely started by me. I did one a few years ago showing the different mounts right next to each other and demonstrating why it wouldn't work to interchange.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 12-23-2013, 09:55 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Here is a good thread on the subject. May be what Kevin was thinking of....
http://67-72chevytrucks.com/vboard/s...d.php?t=442919
LockDoc
Leon
