eBay cheepie swap headers
http://www.ebay.com/itm/1964-77-Chev...7afe3d&vxp=mtr
These things. Are they okay, crap, or somewhere in between? I don't expect complete wonderfulness for $200 but if they are usable I might jump on a set. Found a few threads under "ebay headers" but not much specific to the LS swap headers as listed above. |
Re: eBay cheepie swap headers
There is a fellow on here with a 60-66 truck.
LSx 3rd gen f body swap headers. looks like they fit pretty great. Hope he chimes in. |
meowMEOWmeowMEOW
The outside primary looks like it would hit the engine perch depending how far for/aft you put the motor.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#4 | |
Really like the stainless even though it's probably 409 and will rust after a few heat cycles. Eh. Hooker manifolds are only $100 more. Hose em down with VHT and bake em in the oven just like the olden days. ![]() |
I bought those same headers off eBay, but from a different seller. As far as quality, I'm impressed for $200. All of the welds are solid, the stainless is nice, and mine have roughly 2K miles on them so far and no rust. They did turn blueish yellow up close to the heads, buts that's all.
For my motor mount setup, I used motor mount plates that are 3" forwards, but moved the v8 engine stands back (2.5") to the 6cyl. frame holes. I did this to allow the a/c compressor to bolt up the the factory 5.3 bracket. The only clearance issues I had we on the right side header. At the rear of the right header were the 3-bolt flange is I had to grind a little off of this little rectangle piece that sticks out about 1/2" from the block (probably part of the casting process, but not critical to the block). And then I clearance about 1/8" off of the right motor mount stand to give me more clearance, even though they weren't touching. The left side header fit beautifully. For the price I was very pleased. Here's a pic of them installed, but it doesn't show the back of them.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
Here's a picture of where I had to clearance the block, the circled spot. Not a huge deal to me since I wanted headers that were closer to the block rather than the frame.
I just ordered a set of the hedman 45660 swap headers, I will post once they arrive and get them installed.
![]() Join Date: Jul 2013
I have a set similar to these for an LT-1 and love them. Nice heavy gauge SS and after about 10k miles still look nice. There in my 87 IROC and fit great.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
