60-72 New CPP mounts (and kit)
Anyone have experience with them yet? good? (ya ya ya I know the whole old motor mount fiasco/header clearance issue)
It looks to have the new designed motor mounts (with header clearance) For what its worth.. the mounts, trans xmember, and doug thorley headers are pretty good considering its the same price as ECE members and buying the headers thru summit. That as on my 1966 C10... I will have to cut 1/2" of frame rail edge off to accomodate the ECE mounts I believe. ![]() |
Truck and auto performance nut
Re: 60-72 New CPP mounts (and kit)
those adapter plates look like they place the motor forward?
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
It depends - if the stands go in the six cylinder location, it would end up in the stock location.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
#5 | |
looks like maybe my 6 cylinder lower bolt location fell victim to someones torch...(elongated slots) ![]()
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
good point
I could be wrong, but I think I saw that those kits from CPP have options for the adapter plates to choose your engine position.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#8 | |
I'll have to call but who knows what I'll actually get.... maybe CPPjeff will chime in with a kit part number with the correct position that I need...
![]() Join Date: Aug 2004
I bought those perches and they didnt work for me. I had a hard time finding headers that would work with them.
It looks to me like it would work perfectly and yes you would need to slice a bit off the inside of the frame rail. If I was going to buy from CPP, I would call only Jeff. i would not speak to anyone else there, there has been way too many horror stories on customer service from them and Jeff has been the one shining light IMO. Good Luck!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#10 | |
Looks like they have new options.....
Anyone know the difference between the 322y and 323y Doug Thorley headers?
Anyone else know the difference between kits? I have a 1966...but whats the difference in kits besides headers? (DT doesnt even list a 322y on their website) 1967 Conversion Kit http://www.ebay.com/itm/67-68-69-70-...fdafa6&vxp=mtr 1966 Conversion Kit http://www.ebay.com/itm/63-64-65-66-...4077ea&vxp=mtr
I have the ECE mounts and yes they also require frame trimming.
Vintage Evil
I have the CPP sheetmetal perches with Dirty Dingo sliders. My Doug Thorleys 323y cleared with no problem...
#15 |
I'm about to give these a twirl... wish me luck!
#16 |
Vintage Evil
#17 | |
bring on the wallet pain ![]()
#18 |
![]() Join Date: Nov 2013
How much was the whole kit and whats the part number you used ?? Would i need the same one for my 64 ?? i`m new to this stuff.
#19 |
with the help of chevyguy_72.... I kind of piece mealed it all in the end.
I did use the CPP cross member... but ordered it from summit racing to void having to deal with CPP. I did use the CPP sheet metal motor mounts that I found on ebay.. again voiding CPP's website, and service as a whole. I ended up using dirty dingo sliders I ended up sourcing all this seperately to void the cost of paying for rubber motor mounts and transmission mounts with everything... in order to seperately buy Energy Suspension poly mounts. I will be using the 1-5/8" headers from DT (324 y) as their exit angle is cleaner vs. the 323 and 322 1-7/8" primary headers which they exit somewhere in between a shorty and a long tube. Here is my truck all mock mounted in. ![]() ![]() ![]()
#20 |
Sure is a good feeling seeing that LS sitting between the frame rails of your old pickup truck isn't it?
#21 |
66Lsx
Nice set up. I need to mock up my 99 LS1 into my 63 and want to go with CPP sheet metal mounts but torn whether to get the CPP slidder adapters or the dirty dingo ones. And for the headers I was going to go with some hooker cast iron ones. Like these. What is the total adjustment of the dingo ones forward and back from stock location?
Tommy~ The difference between genius and stupidity is that genius has its limits -- Albert Einstein 63 build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=317341 |
#22 | |
They exit above the trans crossmember and have the 02 bungs already in them... As far as the dirty dingos are concerned... 2.50" of adjustment total... I had NO problem sliding the engine to have the transmission crossmember utilize of the pre-existing holes as well as my original 1pc driveshaft (new slip yoke and u joints tho yes) ![]() ![]() ![]() ![]() yes the exhaust is above trans x member.. poor camera angle.... ![]()
#23 |
Looks like its coming along nicely bud, A quick question though, how much were those headers and wont you have an issue with the exhaust hitting that trans x-member? Maybe its just the angle of that last pic. Thanks
-Steven
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" ![]() 68 GMC K1500 1/2 ton L83/6L80e |
#24 | |
Bad angle.... looks are deceiving....heres a better one.... FYI headers were $616 @ summit.... ![]()
#25 |
Thanks for the added pics. Those headers look sweet. I'm sticking with cast iron though I think for less chances for leaks and and it being a daily driver. Those dingos are pricey. The CPP sliders are $145 shipped with poly mounts through eBay. I think everything will clear.
