Old 12-30-2013, 04:44 PM   #1
ls1man
ls1man's Avatar
rim width???
Is a 235/75/15 wide enough for an 8 inch rim?
ls1man is offline   Reply With Quote
Old 12-31-2013, 12:43 PM   #2
curmudgeon
Re: rim width???
technically a 235/75-15 will fit a 8" rim, although with that width and aspect ratio a 7" rim would be better.
http://www.yokohamatire.com/tires_10...m_wheel_width/
curmudgeon is offline   Reply With Quote
Old 12-31-2013, 02:47 PM   #3
tlorber
tlorber's Avatar
Re: rim width???
There are 25.4 mm's per inch. Therefore, 235 mm = 9.25" mathematically (different tires will lay down differently depending upon tread, and sidewall height affects how much the tire will "bow" beyond the wheel). With mag wheels, generally I've found the exterior wheel dimension to be about 1" wider than the interior (rated) wheel width. I'm not sure about steelies.
tlorber is offline   Reply With Quote
Old 12-31-2013, 03:23 PM   #4
ls1man
ls1man's Avatar
Re: rim width???
I should probably go to a 70 series then.
Old 12-31-2013, 05:04 PM   #5
curmudgeon
Re: rim width???
choice of aspect ratio is more dependent on what total overall diameter you are looking for.
235/70-15 = around 28"
235/75-15 = around 28.9"
Lower aspect ratio tires, 50-55 series, tolerate being stretched out on a wider rim better.
If you already have the 8"rim, a 255/70-15 will give a 29.1" diameter, similar to the 235/75-15. If you already have the tire, I would go 7" rim as mentioned. (assuming this being the rears)
