Old 03-20-2002, 03:35 PM   #1
Nichboy
Post Fuel guage
Fuel gauge in my 71 swb worked fine, installed a new poly tank in the rear, ran a new wire to fuel gauge, have tank filled up but only shows 1/4 on fuel guage. What have i done wrong. Thanks
1971 Chevy SWB
Oklahoma City, Oklahoma
Nichboy is offline   Reply With Quote
Old 03-20-2002, 04:04 PM   #2
Mixup
Post
Same thing happened to me. The float had a pin hole in it and wouldn't float to show a full tank. Only got to 1/4.
1980 Chevy Shortbed Pickup
1969 Z28 engine
Turbo 350
Mixup is offline   Reply With Quote
Old 03-20-2002, 04:08 PM   #3
Nichboy
Post
I thought that is why you buy brand new, so you don't have these kind of problems. i guess i will be pulling the bed off agian.
1971 Chevy SWB
Old 03-20-2002, 05:52 PM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up
Where did you hook the wire? It also needs a ground off of the sender. Need more info
Andy
71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-20-2002, 06:05 PM   #5
busterwivell
Post
If it wasn't grounded, it would read past full, wouldn't it?
Bill - Tucson, AZ
47 Chevrolet 2 dr sedan
56 Chevrolet 210 2 dr sedan
66 Chevrolet Malibu 2 dr 4 speed
71 Chevrolet C30 Longhorn
86 Chevrolet Monte Carlo SS (Sold)
01 Chevrolet Tahoe
IM - BUSTERWIVE@aol.com
busterwivell is offline   Reply With Quote
Old 03-20-2002, 06:34 PM   #6
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Post
Is your old gauge still hooked up and somehow altering the reading? Disconnect your new one and see if the gauge goes to past full (open circuit). Then short it to ground and see if it goes to past empty (short circuit). If both of those tests work, maybe your sender is bad, or maybe the sender doesn't have the right resistance range to work with your gauge.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 03-20-2002, 06:36 PM   #7
Nichboy
Post
Ground appears to be good off tank, and it did read past full until i hooked it up to guage. When i hooked up to guage it went down to almost empty, filled tank up and went up to 1/4 and hasn't moved since
1971 Chevy SWB
Old 03-20-2002, 08:09 PM   #8
71GMC_3/4T
71GMC_3/4T's Avatar
Post
Sounds like either a sunk float or something binding and not letting it come to the top.
Either that, or a sending unit that doesn't match your gauge. Contact the vendor and ask them what the resistance reading of the sender should be at full and empty. Compare that to factory spec, and also to what yours is doing. Just pull the wire and ohm from the wire to ground.
I'm betting you'll end up pulling the tank and sender and either rotating the sender 60 degrees, or bending the arm because it's dragging on the side of the tank. Just a hunch...
Lafayette, CO
