Cpp master cyl and prop valve
Anyone used cpp power disc conv and prop valve have a pic on how it's set up? I turned it sideways to get the line to work but the brackets they sent with it don't come close. Thanx
Re: Cpp master cyl and prop valve
I installed one of these on my buddies truck and used the old proportioning valve bracket, the lines only needed the slightest tweaking to line up. Hope this helps.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
That's probably the best way, but I've already bought there lines so they only line up with there crap. Shoulda consulted the board first. Thanx for your input
![]() Join Date: Sep 2012
I bought their whole setup and the booster was junk right out of the box, I too had to turn the proportioning valve(which was also bad by the way) sideways and the bracket didnt work either! Now To there credit They tried to help me alot and did there best to help me figre out the problem. After chasing the problem for a quite awhile I just went and bought a booster from oreilly(which was what I suspected was bad in the first place) and put the CPP master back on it bypassed the proportioning valve and it works phenominally now!!.. Thing is the booster passed all the tests we did and showed good but it sure wasnt. hope you have better luck than me...!
Jam orris, not to get to far off but my 67 camaro has cpp set up and the pedal always goes to the floor. What was your booster prob
It would not hold any vacuum at all, would not even build any up. I had the new one I purchased right beside it and there was total difference. You can lay it on its face and use your hand to push the rod up and down about 3 times and it should build. My bad CPP one would just pump up and down all day long no pressure.
I've installed 3 of these kits in the last 6 months and have not had any problems.
#8 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
You should be alright, just some days chicken some days feathers. It happens, if you do have problems they'll work with you, master cylinder worked great!!
Yea, its hit or miss with boosters, I worked in parts many years ago and it was the same then. You could get new rebuilds bad right out of the box then, its a thing with boosters and always has been. I got another of the same setup that works perfectly. CPP was nice and helpful all the times I spoke with them, no bad talk about them from me.
