Sway bars and bags?
How are you guys mounting your swaybars with bags? My control arm mounts are welded on but problem lies when laid out I bent the bolt that holds the bushings from to much angle? Is there a high angle link kit for a sway bar? For a 65 Chevy c10
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
![]() Join Date: Mar 2005
Re: Sway bars and bags?
Don't use the factory thru-bolt and bushing set-up on the lower control arm. Weld some tabs on the lower control arm and use a heim joint that can articulate. Or, you might be able to find a clevis with a threaded end and bolt it to the lower control arm, and then use a heim joint. What type of end do you have on your swaybar? If you have a sway bar with an eyelet on the ends, then use the bolt and bushing set-up on that end, and find a female heim that will thread on to the end of the bolt.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Project 7dos
We just got done with our bag install, and took the sway bar off... It's amazing the difference between a static drop with a sway bar, and a bagged setup with no sway bar.... This thing rides on rails now...
Have you tried without the sway bar?
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
#4 | |
Yea ran it all year without it and if you look at my build I put the valves as close to the bags as possible and still want more stability..
Think I got it figured out... Late 90's early 2000 Chevys ran a sway bar link that looks like it will work so I'm going to see what I can fab up..
Happy to be here
![]() Join Date: Mar 2000
Huh? I have found it to be just tho opposite. Adding a sway bar to a bagged truck is a HUGE improvement. You might try putting it back on and test it again.
That's kinda what I thought... I did an install on a cutlass and ended up putting the sway bar back on! My truck I want to handle cornering like autocross cars!
Happy to be here
I have "heard" from others, but I can personally attest to my experience. My 77 Cheyenne did not have a sway bar from the factory. Its was bagged and driven for a full season without one. The next season I found a 1 1/8" bar from a C/20 and installed it with the clamps bolted directly to the frame. There was a very noticeable improvement in stability and a lot less lean in the corners.
I "always" recommend a sway bar with bags.
I would always recommend a sway bar regardless of spring choice up front.
wondering if OP got theirs setup and if so do you have any pics?
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo '81 C-10 SWB Parts Truck IRC - http://webchat.snoonet.org/#baggedtrucks |
anyone have to cut sway bar ends shorter when running with bags???
OK, I have a 1&1\4" or so sway bar I'm mounting on my 83 c10 with bags, plates and cups and drop spindles. I plan on bolting just the 'strap' bands on the bushings directly to the frame and stock LCAs. There is one hole about 2" off more towards the bumper on each side of the frame. No other holes or rivets near where the mount lines up.... Should I have the truck aired out and the sway bar back ends as close as safely possible to the empty bags? Then mount sway bar frame brackets aired out so it draws away from bags going up?? Or does the sway bar even move when clamped up?? What do you think???
Happy to be here
I would set it at ride height and install it from there. You want your end links to be perpendicular at ride height, which means they will be canted when aired out.
#15 |
