72 c30 swap questions
Brake rotors for this c30 I have seem impossible to find and would guess pricey. Since it is a project, could I swap the suspension for say, 73 and up suspension/brakes as bolt on? Its a dually, and the rotors are the ginormous ridiculous mountain versions.
Re: 72 c30 swap questions
I pulled a whole front suspension out of a 73+ truck for my 71 for which rotors are NLA. For a 71 you can replace the spindle-out or the whole front end.
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
73 1 ton over to your 71 1 ton? Any mods?
I have not done it yet, but I did research here on the forum. To swap the crossmember-out you have to drill several more holes in the frame. To replace the spindles out you just swap the spindles, rotors, calipers. I dont think I remember anything about changing ball joints. Several forum members have done it. I am going to rebuild and paint the whole assy and also swap in a 14 bolt to get rid of the 4.56s. 73+ came with a sway bar as well.
Just going to ask you about the rear differential swap as well. I'm leaning at this point to either go with the 1 ton swap or cut the frame and swap over to 1/2. I have an retired California Conservation utility vehicle. I will post pictures tomorrow.
Sure you have to swap spindles? I have a 72 C2500 that I did some research on a while back, and I thought that all the bearings were the same. I also thought the rotors were the same 3/4 and 1 ton srw from 72 up. Will have to revisit this. Just checked Rockauto and they describe that the srw rotors fit from 72 to 89. I would believe that the drw rotors would swap too
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#7 | |
The Older Generation
I'm headed out to the shop so I don't have time to look anything up for you but if you type the words "C-30 brake upgrade" into the GOOGLE search box at the top of this page, click on the circle in front of "67-72chevytrucks.com and click on the GOOGLE button you will find lots of threads on the subject. Here is one of the most comprehensive ones: http://67-72chevytrucks.com/vboard/s...d.php?t=367260 It is not C-30 specific but there is a lot of good info in it. It is on the '60-'66 board but would also cover the later trucks as the frame is basically the same... LockDoc
#8 | |
NAPA shows the same p/n s for wheel brgs, calipers, ball joints, lower control arms 72-78 C30.
Upper control arms show different p/n s. Rotors 73+ are 1 piece hub and rotor 1.54" thick. My 71s are 1 piece hub and rotor around 1.5 without pulling a wheel. My Chevy parts book shows the same spindles C20&30 71-72 but the front brake page is missing. I dont know why this has to be so difficult and why the parts houses show NLA. I guess I will throw a 78 rotor on my 71 and see if everything lines up. Unkle Matt never did say how his setup worked, or what he used. I do know that forum members have put late 70s spindles-out on drum brake trucks.
Here are the pictures I mentioned that I would post. This is a 72 c30 4 speed granny low, with a non stock 327 circa 67. It is a retired California Conservation Corp utility truck turned work truck. The original red paint it came with is still in the interior and in places, exterior.
Is this common for c30 front suspension with the extra leaf spring supporting the lower a arms?
I thought it sat a lot higher in the front than my low rider.
First I have seen one of those.
I lightened the picture up a little and rotated it so it is easier to see... That is some heavy duty springs for sure. Any chance you could post a picture of the sticker from the inside of the glove box door? Does it list any heavy duty springs as an option? LockDoc
#15 | |
![]() Originally a dual battery, dual alternator vehicle. Note the massive wiring sent to the utility bed in back of the brake booster, from firewall. ![]() |
