Old 01-02-2014, 01:39 PM   #1
jd21476
jd21476's Avatar
New speedo gear for new tranny
I swapped out my tranny from a T350 to a 700R4 and now my speedo is reading fast. It says I'm doing 80-90 when in reality I am probably running about 65-70.
Anyone know where to buy a new speedo gear and possibly which on I will need?
I have a '73 K20 4x4 with a 350 and 700R4
1973 Chevy K20
jd21476 is offline   Reply With Quote
Old 01-02-2014, 02:19 PM   #2
77c10
77c10's Avatar
Re: New speedo gear for new tranny
You will need to know your tire diameter and rear end ratio. Google "700r4 speedometer gear calculator" and you will find numerous websites that have charts.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 01-02-2014, 02:32 PM   #3
tlawre87
tlawre87's Avatar
http://www.transmissioncenter.net/sp...__va.htm#700r4
That will allow you to purchase the gear.
This will allow you to calculate:
http://www.tciauto.com/tc/speedometer-gear-calculator/
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 01-02-2014, 02:36 PM   #4
jd21476
jd21476's Avatar
So to get the drive teeth I'm going to have to open my rear diff, correct?
1973 Chevy K20
Old 01-02-2014, 03:03 PM   #5
77c10
77c10's Avatar
To be 100% certain, yes...
Old 01-02-2014, 08:13 PM   #6
mrolds88
Not really. On a flat spot, jack up one rear wheel (after blocking at least the opposite wheel on the front. Put the truck in neutral. If the truck doesn't have a posi or limited slip, you will be able to turn the rear wheel that is in the air. If this is the case, make a mark on the tire and one on the pinion. Now turn the wheel and count how many times it turns to get the pinion to turn twice. That will give you the gear ratio. If it takes a little over 4 times to turn the pinion twice, it's 4.10's. Now if it has a posi, you will have to lift both rear wheels and turn a tire. But this time you will turn the tire as many times as needed to turn the pinion once.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-02-2014, 03:11 PM   #7
tlawre87
tlawre87's Avatar
If you have the 4.10 you should, anyone chime in if Im wrong because this is not a strong area for me, technically have 41 teeth on the ring and 10 on the pinion. Check the SPID for the ratio or jack it up and count the driveshaft revolutions to the wheel turn.
Trevor
Old 01-02-2014, 03:13 PM   #8
geezer#99
geezer#99's Avatar
Easier yet is figure out the percentage off your speedo is and buy and install a ratio adaptor. There's some on the post tlawre87 gave you in the link.
Old 01-02-2014, 03:53 PM   #9
jimbonice
jimbonice's Avatar
Check out the faq's section; there's a link to a speedo gear calculator. When I went from a turbo 400 to a 700r4 in a 4.11 geared dually, I had to change both gears. No big deal, but the tail shaft has to come off for the inner gear.
jimbonice is offline   Reply With Quote
