07-18-2003, 12:21 AM | #1 |
tool for cutting steel
What tool would you recommend for cutting 10 to 14 gauge sheets and 1/8th inch angle iron?
07-18-2003, 12:34 AM | #2 |
Pesemistic Optimist
Metal shears (electric/air), plasma cutter, metal chop saw.
07-18-2003, 01:31 AM | #3 |
I've always had good results just using a zip cut (cutting wheel) on a grinder. As long as you could run it straight it will cut no problem.
Q |
07-18-2003, 01:32 AM | #4 |
If you want a good clean cut, it's not for you, but i've always liked the good old oxy-acetylene (how DO you spell that?) torch for cutting steel.
Brian Pal 1971 Cheyenne 10 454/th400-Undergoing a full frame off resto. 1972 Chevy short/step 2wd, 350/th350 1983 M1009 CUCV Military K5 Blazer 1981 Dodge 1 ton 4x4 dually flatbed |
07-18-2003, 02:47 AM | #5 | |
Bloo
i'll second the torch, but if you set it up right you can get a realitivly straight cut on thicker metal (i was cutting a frame)
when you get the oxygen set right, lean the tip where it heats up a long strip of the metal to almost dripping melted, then hit the button and go through it as quick as you can and still cut it
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
07-18-2003, 03:05 AM | #6 |
Registered Abuser
If you have a power saw (i.e. skill saw), you could use a carbon blade in it and get really good results that way.
07-18-2003, 04:52 AM | #7 |
What if?
i use a zaw-zall for most of my metal cutting,works pretty good if ya keep it straight. heck even a jigsaw with a metal blade works good.
2002 red extended cab Silverado 2002 Wheatland yellow Suburban |
07-18-2003, 08:51 AM | #8 |
Depending on the size of the piece to cut, the best thing I have found is the little horizontal/vertical bandsaw from Harbor Freight. About $175. I also have a chop saw that has not been out of the closet since I got the bandsaw.
It works great for cutting off long stuck even up to 1" thick. Just takes awhile. But it's quiet. If you need more speed for big stuff, use the torch. I just can't recommend a chop saw ever over the bandsaw. I have the cheap saw but some moderately priced Starrett blades for it that make a big difference.
07-18-2003, 12:39 PM | #9 |
I agree with sarge, a sawzaw or a jigsaw works best fo me as well, and you can make curved cuts with a jigsaw.
07-18-2003, 12:48 PM | #10 | |
Wiseass secured himself a BAN
07-18-2003, 08:41 PM | #11 |
I like the jigsaw but I always hate how the blades are held in, maybe I need a better saw
07-18-2003, 08:49 PM | #12 |
i'd love to have a plasma cutter and a nice upright bandsaw but for now like the other guys said the old $30 jigsaw with a good carbon or bimetal blade works pretty darn good up to 3/8 inch steel
07-20-2003, 08:01 AM | #13 |
Just a tip for torch users.
Take a center punch and place small dimples along your cut line about every 1/2 to 3/4 inch apart. When you cut these show up very nicely and makes the cuts a little nicer with practice.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
07-20-2003, 10:32 AM | #14 |
Weapons Of Construction
Another tip for torch users:
Clamp a piece of angle iron about 1/4" away from your line. Use the angle to support / guide your torch while you cut.
1971 GMC 2500, 402/TH400 4.10 Daily Driver Lafayette, CO |
