What Ball Joints ?
Hey guys an gals!
Im trying to find out what ball joints i need to fit my 71' Disk spindles to my 64' Control and A-arms? Size ? Id really Appreciate it ! thanks in advance
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625 1969 Chevy Nova 2 dr I6 250/powerglide 1967,68,69,70,71,72 Chevy Frankenstein |
Re: What Ball Joints ?
you need the same ball joints that your spindles used originally. There are a lot of in depth posts that go into all the parts and pieces to do this swap.
60-66 Nut
You simply need the balljoints for a '71-'72 C10. One of them is specific to those 2 years only. I don't remember if it is the upper or lower. That's the reason I don't like to use those spindles.
67-72 parts collector,…
![]() Join Date: Nov 2002
Uppers are 71-72 specific.
Lowers are 71-87. You will need 71-72 outer tie rods. Which won't bolt to your existing steering because they are the wrong diameter and opposite thread. You'll need either: All 71-72 steering parts. Or conversion sleeves and move your original outer tie rods to the inner location. Or best answer,... Throw your 71-72 spindles in the trash and buy 63-70 conversion spindles for $229. No need to change anything.
Thanks for the help guys! i may just sell the whole front suspension crossmember and all for the 71' and buy the conversion spindles.
Moog K6117 is what i used for my lower balljoints.
