Old 01-08-2014, 11:20 PM   #1
Fangio
Fangio's Avatar
Drive shaft rubbing trailing arm crossmember
I have a 64 long bed 350/th350 with a 3/4 drop from CPP and a one piece driveshaft. With a decent sized load in the bed the driveshaft rubs on the trailing arm crossmember. What are the options to fix this?
I would like to go a little lower all around, does that mean I am stuck getting an aftermarket or modified trailing arm crossmember at some point?
Are airbags in the rear the best option to maintain a decent ride and to be able to carry a load? Thanks.
Fangio is offline   Reply With Quote
Old 01-09-2014, 04:12 AM   #2
argonaut
argonaut's Avatar
Re: Drive shaft rubbing trailing arm crossmember
Cut the rivets out and flip the crossmember over?
I don't do lowered trucks anymore but once upon a time i remember thinking that would work.
Jason M. @argonaut62
1972 K5 Blazer CST, Turquoise
1966 K20 Short Fleet Pickup, Big Ugly
1964 C10 Short Fleet, Gertrude
2001 Porsche 911 Carrera
1996 Ford Bronco XLT
1980 Jeep Wagoneer
2008 Honda CBR1000RR
2005 Honda RC51
1981 Honda CB750C
No dis-assemble Johnny Five! No dis-assemble!
argonaut is offline   Reply With Quote
Old 01-09-2014, 08:25 AM   #3
apachedaddy
apachedaddy's Avatar
or put the 2 piece drive shaft in with a carrier bearing.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 01-09-2014, 10:39 AM   #4
familyfast64
familyfast64's Avatar
Mine almost hits the upper passenger side of the hole as well. Mines lowered with a 9" but I have the swb. I don't think it actually hits tho, just real close. I've seen guys that just cut the hole in the crossmember a lil larger in the area it hits.
Live and let live
familyfast64 is offline   Reply With Quote
Old 01-09-2014, 07:11 PM   #5
Fangio
Fangio's Avatar
Thanks for the replies. My other concern is that the rear spring rate is too low, are there any lowering springs out there that are a little stiffer? Is it worth messing with helper springs or would an airbag setup be best?
