01-09-2014, 08:37 AM | #1 |
Front A Arm Swap will it work?
I have searched around but not able to get a complete answer to my question.
I have a 1967 C20 4x2 and I want to swap to disc brakes but also the newer 73-87 a arms for the better style bushings. My question is I know you can swap out the whole front cross member but I would like to just swap over the upper and lower a arms and spindles to my existing 1967 cross member. Has any done this or can it be done? |
01-09-2014, 09:42 AM | #2 | |
Re: Front A Arm Swap will it work?
01-09-2014, 09:52 AM | #3 |
67-72 parts collector,…
You will also need to swap the entire 73-87 steering linkage to make the swap easier.
(the tie rods have to match the spindles)
