01-09-2014, 12:54 PM | #1 |
prop valve time
i need to replace my prop vavle as its stuck blocking off my rear brakes, not local stores have them where is the best place you've find them for a decent price/. good quiltiy part? i know brake parts aren't a place to cheap out at but i really don't want to spend 150 dollars on a valve. whats the difference between the brass ones and the stock cast one? mine also does not have a reset button on it and is stuck in the rear closed spot as it sit with no mast cylinder on it.
i also have stomped the pedal hard several times trying to reset no luck
01-09-2014, 03:38 PM | #2 | |
The Older Generation
Re: prop valve time
Dave, Here is one that NAPA has: http://www.napaonline.com/Catalog/Ca...552_0355352928 I don't have any personal experience with it. And here is one from e-Bay: http://www.ebay.com/itm/CHEVY-GM-Pro...-/161058469851 Seller has 99.9% feedback with almost 5000 items sold. That is good... LockDoc
01-09-2014, 05:30 PM | #3 |
Re: prop valve time
If it doesn't have a reset button I suspect it isn't a prop valve it is the distribution type valve that came stock on drum front n rear brakes up to include 69 model year. Sure someone will correct me if I am wrong. I have seen trucks that were converted to disks with the older distribution block. Doesn't make them as responsive without the proper valve.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-09-2014, 06:17 PM | #4 |
Re: prop valve time
Its a 71 with factory disc brakes
