Old 01-11-2014, 08:13 PM   #1
Hotrod1952
66 Build
Working on a 66 C-20 longbed since August 2013. Replaced all the rusted panels in the floor. Removed front and rear suspensions blasted and powdercoated the frame rails. I purchased an 87 silverado rust bucket with 90K miles and drove it for 2 months it runs and shifts great. Presently dismantling the 87. I plan to install complete front crossmember and power steering into the 66. Anyone have alignment specs for something like this? Was going to rebuild the motor/trans but for now will just clean paint and install into 66. I plan to remove all the air pump and egr and rest of the smog stuff and use the 87 wiring harness for the tbi motor. Future plans include installing the 87 rear end (3.42 Ratio) and leaf springs as well andl install a set of duramax aluminum wheels on the 8 lug suspension.
Hotrod1952 is offline   Reply With Quote
Old 01-11-2014, 09:44 PM   #2
rusty76
rusty76's Avatar
Re: 66 Build
Well welcome to the forum and looking forward to pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-11-2014, 11:38 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Re: 66 Build
Welcome! X2 on the pictures!
Old 01-12-2014, 12:05 AM   #4
Hotrod1952
Re: 66 Build
Front end removed.
Box is off.
Old 01-12-2014, 12:10 AM   #5
Hotrod1952
Re: 66 Build
Frame with suspension removed.
Building 1/2 ton style mounts.
Did i say the floor had rust? 4 weeks of fixing...
Old 01-12-2014, 12:14 AM   #6
Hotrod1952
Re: 66 Build
Still repairing rust.
Big back window donor section.
Finally the floor in primer!
Old 01-12-2014, 12:18 AM   #7
Hotrod1952
Re: 66 Build
Cab in primer!
Building drop dash for A/C Ducts. Vents will be from a 66 fullsize Chevy. Center is from a Buick Sportwagon.
Fixing a fender.
Old 01-12-2014, 12:22 AM   #8
Hotrod1952
Re: 66 Build
Getting ready to remove rear suspension fron the 87 donor truck.
Old 01-12-2014, 05:09 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
Re: 66 Build
JFYI. You can upload pictures using this site.....just go to the "manage attachments" option....they should come out bigger....thanks for posting.
Old 01-13-2014, 03:41 PM   #10
Hotrod1952
Smile Re: 66 Build
Lets try these. Should be better quality. Thanks TJ for pointing that out.
Old 01-13-2014, 04:03 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Re: 66 Build
Nice work!
Old 01-27-2014, 11:43 AM   #12
Hotrod1952
Re: 66 Build
Time to get a few more pics up...
Old 01-27-2014, 11:54 PM   #13
Jeff La
Re: 66 Build
Dash extension is definitely a great start
Jeff La is offline   Reply With Quote
Old 02-06-2014, 06:53 PM   #14
Hotrod1952
Re: 66 Build
Time for a few more pics. Working on front suspension yet. Waiting now for Western Chassis drop Spindles for 3/4 ton. Belltech 3100's I bought won't work. Anybody need a set? Swaybar is 1 1/16" and fits nice off the 87.
Old 02-06-2014, 08:06 PM   #15
1963c-10
1963c-10's Avatar
Re: 66 Build
Welcome and great job on the floor patches. Alot of people would have replaced the cab and I admire the amount of dedication and work you went through to keep the original cab and do the work yourself. Keep up the good work.
1964 Short bed trailer
Old 03-08-2014, 03:53 PM   #16
Hotrod1952
Re: 66 Build
Been working on Front suspension install, Steering column, Drop dash. 2.5" Western Chassis drop spindles. Modified the 87 pedal unit to fit so I could get correct pedal ratio. Shortened the 87 column 2.5" and removed key/column lock stuff. Mounted 87 booster. Trimmed the drop dash to fit around the column. Fabbed up a steering box bracket. Looks like the shaft from the column to the steering gear will fit without having to collapse it. Guess my measurements worked out.
Old 03-17-2014, 02:22 PM   #17
Hotrod1952
Re: 66 Build
More to come. Need to fab a inner fender next...
Old 03-19-2014, 09:39 PM   #18
Hotrod1952
Wink Re: 66 Build
Got firewall painted tonight.
Old 03-21-2014, 09:29 PM   #19
Bomp
Bomp's Avatar
Re: 66 Build
Man you work fast.
Sub'd
Bomp is offline   Reply With Quote
Old 03-22-2014, 02:44 PM   #20
Hotrod1952
Re: 66 Build
Stayed up late Friday night got all the dash pieces & interior of cab painted. Used single stage enamel had it matched to paint code 22151 PPG lacquer color. The dash originally wash a shade darker, but I like the lighter color so I'm going all one color.
Old 03-26-2014, 12:39 PM   #21
Hotrod1952
Re: 66 Build
Time to get a couple photos up.
When I installed the firewall pad I cracked the sheet metal next to a weld I made in the firewall. So I got to do a spot repair on the newly painted firewall.
Working on getting dash assembled. Brake pedal and booster, steering column, fuse box, cable accelerator pedal, cut a hole for the 87 temp control to mount in the drop dash(I plan on installing a heater delete where the 66 control was), and wiring harness. Since I am using the 87 harness and computer I will have to figure out the ignition switch wiring. I also want an accessory position so I ordered a switch for a 61-63 impala. I read on a forum somewhere that I can install my key tumblers in that ignition switch. I also ordered a Jags #2prs speed sensor so I can get a speed reference into the ECM. I mounted the ECM behind the glove box above the heater. Similar to where it was in the 87. Next up after the Ignition switch will be figuring how to make a 66 wiper motor work with a 1987 intermittent wiper system. I would like to have intermittent wipers and have the switches on the 87 column already.
Hi Brandt
Old 03-26-2014, 06:29 PM   #22
McMurphy
McMurphy's Avatar
Re: 66 Build
Your dash extension is very clean !! Nicely done
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 04-20-2014, 05:34 PM   #23
Hotrod1952
Re: 66 Build
Okay. Time to get some more photos up. I got the motor set in place. I used stock 66 mounts and ended up modifying the perches to get the exhaust manifolds to clear. I also ended up moving the engine/trans 1" forward and drilling new holes for the perches. I used a stock 87 r20 2wd trans cross member. After all was said and done I found a 94 Chevy van aluminum 1 piece drive shaft at the local auto salvage (63.5" long). Changed the U-joints and shortened the front yoke spline end 1.25" and it slid right into place. Wired up the original ignition switch (with a couple relays for the current). Poured a couple splashes of gas in the throttle body and she fired right up!
Old 04-27-2014, 08:52 AM   #24
Hotrod1952
Re: 66 Build
Working on getting rear fuel tank installed. I bought a new Tank for a Blazer knowing it would take some work to get it to fit. Ended up making cross frame box floor supports out of heavy wall 1" tube for the tank rest against on top. I plan to cut the box cross members down where they cross the frame for clearance of the tank. Also ended up removing and filling filler tube and installed it lower down on tank. Welded all up and covered it with JB weld. Also removed 90 Ohm resistor unit from sender and tack welded a 30 Ohm unit onto the tank mounted fuel pump/sending unit.
Old 05-05-2015, 10:13 AM   #25
TJ's Chevy
TJ's Chevy's Avatar
Re: 66 Build
Very nice!
