Old 01-12-2014, 09:39 PM   #1
68'CTown
68'CTown's Avatar
68 Gas Tank Mounted Today!!!
I have my frame powder coated in black and got that back couple weeks ago. Today I just mounted my camaro gas tank that I am doing. I did stainless steel paint for accent colors also which I will be doing on the rest of my truck. Here are some pictures.
Thanks!
Craig
- Every day is a new opportunity. You can build on yesterday's success or put its failures behind and start over again. That's the way life is!
68'CTown is offline   Reply With Quote
Old 01-12-2014, 10:06 PM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: 68 Gas Tank Mounted Today!!!
Silver & black do so well together...looking good!
ETsC10 is offline   Reply With Quote
Old 01-17-2014, 09:33 AM   #3
Keithpep
Go Raiders!
Keithpep is offline   Reply With Quote
Old 01-17-2014, 09:50 AM   #4
Bluechevy68
Bluechevy68's Avatar
Nice job. Would be the way I would do it also.
Bluechevy68 is offline   Reply With Quote
Old 01-12-2014, 10:23 PM   #5
profe56
Good job.
How's the tank going to be filled, By the license plate.
wath camaro year?
profe56 is offline   Reply With Quote
Old 01-17-2014, 01:27 AM   #6
68'CTown
68'CTown's Avatar
Thanks! I am doing a flip down license plate bracket and I can't remember but believe the gas tank is 68 or 69 camaro. It fits really nice.
Thanks!
Craig
Old 01-17-2014, 09:26 AM   #7
72bowtiestepper
Nice Job...looks good ! I like the way you fabbed your brackets for the tank straps.
72bowtiestepper is offline   Reply With Quote
Old 01-17-2014, 11:18 AM   #8
KellerMAC
KellerMAC's Avatar
Great Job on the mount - I did the same on my rebuild and it works great. I used a 69 Camaro tank and it bolted up fine. I took it one step forward I cut the filler neck from the factory behind the seat tank and used it on my new tank.
I also took the factory fuel tank and converted it to a speaker box - I had it flushed, and then I batted it, installed speakers, and then covered it with carpet - fit like a glove and sounds great!
I have enclosed a few pictures.
Good luck!
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 01-29-2014, 11:00 AM   #9
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Good luck!
That was a good idea and i like the way it looks.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 07-30-2014, 08:47 PM   #10
jd7
jd7's Avatar
Good luck!
looks great what did you do for a sending unit ?
jd7 is offline   Reply With Quote
Old 01-17-2014, 12:49 PM   #11
cool68
looks great
cool68 is offline   Reply With Quote
Old 01-29-2014, 06:51 AM   #12
THE BOSS
^^^ something like that is what I'm going to do, but more amps and speakers
I'm an old rocker and half def!
THE BOSS is offline   Reply With Quote
Old 01-29-2014, 11:01 AM   #13
Mr Chevorlet
Rusty Nuts
Nice job on the install
Larry
Mr Chevrolet
Old 07-30-2014, 09:55 PM   #14
68'CTown
68'CTown's Avatar
Thank guys and the sending unit is from the 69 Camaro tank.
Thanks!
Craig
Old 07-31-2014, 12:38 AM   #15
SierraMtns
SierraMtns's Avatar
How did you vent the tank?
I am putting in a LMC tank right now and not sure how I am going to vent it.
SierraMtns is offline   Reply With Quote
Old 08-01-2014, 11:16 PM   #16
68'CTown
68'CTown's Avatar
SierraMtns: I just used a vented fuel line and then the gas cap.
Thanks!
Craig
Old 08-02-2014, 02:10 AM   #17
mechanicalman
68'CTown-it appears you have your tank flush against the frame as opposed to others who have it spaced down appox. 1.5-2". KellerMac also has his down, using a chrome bumper and his filler is in the upper half of the license plate area.
I'm building a 68 as well and want to decide on a tank, filler, etc. I like the way you did yours with the tank higher up, but was wondering if you intend to use a roll pan and put the filler up higher just maybe below the tailgate?
mechanicalman is offline   Reply With Quote
Old 08-02-2014, 03:03 PM   #18
In The Ten Ring
I don't think I've ever seen so many washers used on one bolt.
But if it works, that's all that matters!
I am fond of the fold-down license plate fuel opening so KUDOS there.
Thanks for all the pics and I am glad you have her done.
In The Ten Ring is offline   Reply With Quote
Old 08-02-2014, 07:28 PM   #19
profe56
I like this job you did on your truck, but its safe? I mean when you make a stop the gas tank cap don't let leak gasoline?
1968, gas tank, tank, truck c10
