Old 01-13-2014, 12:05 AM   #1
Lil Ape
Installed new valve covers, now have smoke/steam coming out from breather.
I installed new edelbrock chrome valve covers with baffles. They replaced another set of eddy covers that were rusted and just looked nasty. The two valve covers are the exact same part number. And after a few drives, I noticed smoke or steam coming out from the breather, only when at full operating temps. I just installed new headers too and though I had a bad gasket, but its not coming from the headers, or out of the sides of the valve cover, only the breather.
I'm assuming this isn't normal, is it? It never did this with the old valve covers. And the rubber seals are brand new. Engine only has 75 miles on it since rebuild. I have a breather on the passenger valve cover and a oil cap on the driver. And I read that I should have a pcv instead of an oil cap. Pcv on one side, breather on the other. Is this true?
Lil Ape is offline   Reply With Quote
Old 01-13-2014, 12:16 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Installed new valve covers, now have smoke/steam coming out from breather.
That's crank case gasses building up and escaping. If the motor has only 75 miles on the rebuild then it's not fully broke in yet. Pressure is prob going past the rings some
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-13-2014, 12:35 AM   #3
Lil Ape
Would it be a good idea to go ahead get rid of the oil cap and run a pcv system? Could it alleviate the pressure built up in the crankcase?
Old 01-13-2014, 02:00 AM   #4
cool68
** will help keep oil mist off valve covers from breathers and send spent gases up to carburetor air cleaner base.
cool68 is offline   Reply With Quote
Old 01-13-2014, 04:26 AM   #5
69heavychevy
69heavychevy's Avatar
ALWAYS run a PVC
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
