Old 01-13-2014, 12:36 AM   #1
ivorton74
ivorton74's Avatar
ebay lsx swap adapters
I was looking online for some plates that are adjustable but not as expensive as the dirty dingo one and came across this on ebay...would this one work on my 74?
http://www.ebay.com/itm/301055754967
ivorton74 is offline   Reply With Quote
Old 01-13-2014, 02:08 PM   #2
Matt Cramer
Re: ebay lsx swap adapters
That arch shaped cutout is a little pointless, but I don't see why not.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-24-2014, 01:33 AM   #3
IIGW
Originally Posted by Matt Cramer View Post
That arch shaped cutout is a little pointless...
some mounts have a hump and youd need to grind off the hump, so this mount has the middle removed so you dont have to modify the mount. so its not pointless, its actually well thought out.
and if you have access to a welder, for the price of the mounts you can make your own for under 20 bucks.
IIGW is offline   Reply With Quote
Old 01-13-2014, 03:43 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The holes look to be in the right place. Just be wary of generic hardened hardware that comes with ebay stuff. I've heard everything from getting generic hardware store bolts, to black painted grade 5's (not in terms of the mounts, but various ebay parts over the years)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 01-13-2014, 05:49 PM   #5
doubeys_nova
DD adapters have been used by a lot of people with a great success rate. not to promote DD but in my opinion engine mounts take a beating and would not be where I would personally take the chance. I have DD mounts and have been abused as much as my little 4.8L will abuse them without fail. i guess a bigger deal if you have solid mount engine mounts vs rubber/poly. The mounts I bought was the entire upper engine mount as one piece, not an adapter to your old upper mount.
doubeys_nova is offline   Reply With Quote
Old 01-13-2014, 11:13 PM   #6
Blackpony
Blackpony's Avatar
I am using those exact adapter plates on my 85 and they fit great! Hardware seems to be of good quality, 1 year and no problems thus far.
Blackpony is offline   Reply With Quote
Old 03-08-2014, 11:18 AM   #7
Lq9'ed 80 Sierra
Do they clear low mount ac bracket ?
Lq9'ed 80 Sierra is offline   Reply With Quote
Old 03-08-2014, 02:27 PM   #8
Lq9'ed 80 Sierra
Not sure if I asked you yet but are you using low mount ac bracket ?
Old 01-13-2014, 11:33 PM   #9
ivorton74
ivorton74's Avatar
im thinkin now maybe I should just go with the dingos...may be well worth it in the longrun
Old 03-08-2014, 02:35 PM   #10
solidaxel
solidaxel's Avatar
DD mounts allow you to use your column linkage, in the same location and the drive shaft does NOT have to be messed with fits in the same location and the valve covers do not hit the firewall, first time fit and worked great on my 78 SWB
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-08-2014, 11:35 PM   #11
truckdude239
truckdude239's Avatar
not really true i used the drity dingo sliders and only thing that lined up was the stock linkage, i had to shorten my drive shaft over 6 inches
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 01-14-2014, 10:50 AM   #12
Billett
Billett's Avatar
I bought those exact plates as well. Pretty solid construction and the bolts don't seem like run of the mill hardware store stuff. Mine came unpainted but I imagine they'd look great powdercoated.
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 01-14-2014, 02:18 PM   #13
ivorton74
ivorton74's Avatar
How are they holding up? How long have u had em for?
Old 01-14-2014, 04:33 PM   #14
Billett
Billett's Avatar
Picked them up last summer, so it hasn't been all that long. My truck isn't even tuned yet to be honest, but I've still driven it a few thousand miles on poly mounts. Seem to be doing fine. They have a really nice weight to them that gives me some confidence. I actually heard about them from ls1tech so you might want to search there too to find some reviews. Seller is cutthroat4x4 but I believe his real name is Matt.
Will
2024 Toyota Sienna
Old 01-14-2014, 09:42 PM   #15
ivorton74
ivorton74's Avatar
ok kool man thanks...that's the seller...I have the mounts on my ebay watch list
Old 01-24-2014, 08:59 PM   #16
ivorton74
ivorton74's Avatar
So I ended up getting these mounts on ebay. I thought it came with the green thing in the pic above but the guy said it was just to show the adjustability feature and is not included. So how does the mount work since I have clam shell style mounts?
Old 01-28-2014, 11:13 AM   #17
67c10rustbuket
67c10rustbuket's Avatar
The green thing looks like a universal solid motor mount. You can use the clam shell bracket off of your block, different shape but same bolt pattern. Random pic from elsewhere on this site:
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 01-28-2014, 11:46 AM   #18
gagliano7
Go with the dirty dingo's simple and adjustable
gagliano7 is offline   Reply With Quote
Old 01-28-2014, 12:05 PM   #19
Billett
Billett's Avatar
...and almost triple the price...
Will
2024 Toyota Sienna
Old 01-28-2014, 02:33 PM   #20
ivorton74
ivorton74's Avatar
yep...saved over 60 bucks getting this one instead...money I could use for something else in the swap
Old 03-08-2014, 02:43 PM   #21
solidaxel
solidaxel's Avatar
Do you have to shorten your drive shaft with these mounts?
LS 3 4L70E
Old 03-08-2014, 12:43 PM   #22
ivorton74
ivorton74's Avatar
I'm not sure...I'm not running a/c on mine
1983 C10 Silverado 5.3 swap
1974 C10 lwb 5.3 swap(sold)...http://67-72chevytrucks.com/board/sh...d.php?t=614122
2001 BMW 530i 5 speed
2019 Nissan Titan SV Midnight
1979 Datsun 210 4 door
1980 Datsun 120y(back home in Trinidad)
Old 03-08-2014, 03:33 PM   #23
ivorton74
ivorton74's Avatar
I dont know yet as i havent started the actual swap yet but it is a 3 position mount plate...stock location, 1 inch forward and 1 inch back. Billett and Blackpony are running these mounts too...maybe they'll input some info about the driveshaft
As for the shift linkage I have a b&m floor shifter in my truck so ill have no problems with that...hopefully lol
Old 03-08-2014, 03:35 PM   #24
ivorton74
ivorton74's Avatar
I painted them and mounted them to my engine yesterday...fits up perfect and the hardware works well
Old 03-09-2014, 02:11 PM   #25
Billett
Billett's Avatar
I swapped to a 4l80 so I needed the driveshaft cut anyway. Same with the linkage, Mine was a 4 speed on the floor, with a 3ott column. Swapped to a tilt auto column and picked up the lokar shift linkage kit. No problems with clearance issues though.
Will
2024 Toyota Sienna
