RAT1968 '68 Cab/'71 Parts
What Did You Do To Your Truck Today
Don't know why...But the main WDDDTYTT thread is closed.
Oh well. I used mine for a grocery getter.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Re: What Did You Do To Your Truck Today
I've got the inner and outer heater boxes out. The inner fender well is out. I'm scraping, scrubbing and sanding everything that is currently exposed in that area so I can shoot it with some Rustoleum and start putting it back together. A show truck this is not, but I'll make it look half ways decent by summer. Wait, it's 85° in LA today... it is summer, right??
![]() Join Date: Nov 2013
Cleaned a mouse nest out of the heater. It was right between the fan and the heater core. Worthless little creature's.
fixed the same problem. also installed a new blower motor. it actually got cold enough here to need a heater.
#5 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I have just started work on this 1970 c10 after 25 yrs started by getting engine from another truck I have cleaned up and reassemble
today: removed old 6 stud axles and installed used axles from 1973 1500 removed front spindles with 6stud drums replaced all ball joints and installed used spindles from a 1973 c15 with 5stud rotors ,removed power steering box from donor 1985 c25 with all steering components attached reassembled all pieces onto 1970 c10 swapped over used tires for a rolling chassis |
i added a quart of oil
