01-14-2014, 05:58 PM | #1 |
Junior Member
Shock Absorber Question
Hey everyone, I have a 6in lift and want to go to a 4in. I was wondering if I could just use the shocks that I have which can accommodate 6in of lift with the new 4in kit. I can't see why it would matter but thought I'd get some insight from 67-72. What do you guys think?
01-14-2014, 07:34 PM | #2 |
Re: Shock Absorber Question
Two inch difference it should be ok. As long as it doesn't bottom out when the spring flexes. I believe a lot of shocks for lifts go for 4-6 inch lift are the same size.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
01-15-2014, 12:48 PM | #3 |
Junior Member
Awesome, thanks for the info. It is much appreciated
01-15-2014, 04:21 PM | #4 |
What lift will you be using?
01-15-2014, 04:26 PM | #5 |
Junior Member
I've got super lift 6" springs all the way around right now so to bring it down to 4" I needed to buy 4" springs for all four corners. I'll also be using the ORD zero rate. I went with Superlift again because I was looking at DustinU's thread and liked the results he got with that combination of Superlift springs and the ORD zero rate.
01-15-2014, 06:09 PM | #6 |
So you're going to have a five inch lift. Keep the shocks you got with no problems. Unless they have been beat to hell they'll work fine.
