01-20-2014, 05:20 PM | #1 |
2005 suburban z71 rear heat issues
I had to go up north for a couple weeks and it looks like my rear heat is inop
Electrically and motor wise it's fine. But there is zero hot coolant going into the rear heater/ac box I replaced the water pump and t-stat last spring(it was leaking coolant) Either there is massive vapor lock at the rear heater core or there is no water flow... The hot pipe to the back is only warm right at the front wheel well Or the casting on my new water pump is not right and the flow is wrong Just looking for ideas before I grab another new water pump and T-stat My question is is there a way to bleed air from the rear heater lines or what? 5.3L z vin. Flex fuel motor Thanks in advance Ed
Ed will be known as the Tiger Woods of the integration business |
01-22-2014, 02:31 PM | #2 |
Re: 2005 suburban z71 rear heat issues
Problem solved.
Replaced water pump t-stAt and flushed out the heater cores reverse and forward Replaced all coolant good to -30f Rear heat now works. My hunch is a combination bad t-stat poorly cast water pump. No junk in coolant when I reversed flushed Hope this helps somebody Water pump and t-stat took about an hour to R&R Flushing about an hour. Had to make some special tools included in that hour
