9 inch rears
I wanna see some 73-87 trucks with 9 inch or built 12 bolt rear ends. I'm interested to see some racing setups just for ideas. Any places build bolt in rear ends?
Re: 9 inch rears
I don't know of any bolt in 9 inches but talk to http://www.quickperformance.com/ they will custom build any width you want.
Always a work in progress
Re: 9 inch rears
They will build you a bolt in one as well
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
Re: 9 inch rears
I imagine Currie can fix you up as well.
As a counter point - I still have the 8.5" ring gear 10 bolt in my Chevelle. It's the original housing with a Mark Williams spool and axles, c clip eliminators and welded tubes. I'm at just shy of 1000 hp naturally aspirated, 3950 lbs for high 9/low 10 sec ETs. I broke the pinion four or five years ago, threw another ring and pinion in (at the track) and kept right on going. That's the only time I've ever broke anything related to the rear. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Re: 9 inch rears
i bought this from dtscustom...
9" ford w/ 31 spline axles, bolt circle of 5-5 1/2x20x2" wheel studs 3.25 gear ratio w/true-trac posi 1350 yoke and strap kit (also sending a combo u-joint) set up for stock drum brakes spring pads and shock mounts installed on housing you can look thru my build thread for more info... i think it starts on page 13 good luck
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy Last edited by naphtali5725; 01-22-2014 at 08:59 AM. Reason: added info |
Re: 9 inch rears
I see you've done a flip on the axle, could the axle be ordered with the spring pads under the tube?
Re: 9 inch rears
the spring pads are in the stock location, i put a lowering kit on the back, so now the rear is on top of the springs instead of under it...
My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=515829 Disabled Veteran 82nd Airborne Division Operations: Desert Shield, Desert Storm, and Uphold Democracy |
At the body shop.
Re: 9 inch rears
![]() '79 f100 housing. Narrowed one side to center the pinion. 3:82 gear locker Moser axles. 50+ passes and a ton of street miles.
" That didnt make it any newer " " Dont antique the equipment " |
Re: 9 inch rears
Check with Moser, they will make anything you need.
