01-22-2014, 06:57 AM | #1 |
Body mount kit where to get it?
Hey I need a body mounting kit for a 1983 shortbed k10 all I can find is bushings for it and I need complete hardware with bushings. Where can I find one?
01-22-2014, 07:29 AM | #2 |
Re: Body mount kit where to get it?
Head on over to wwww.lmctruck.com , you'll find just about anything for an '83. Just navigate through the site and it should point you right to tonnes of parts for your truck.
If It runs like a Chevy, it probably is! |
01-22-2014, 07:40 AM | #3 |
I did but it's 200. That seams a little steap to me, any other spots where I can find one?
01-22-2014, 10:17 AM | #4 |
Someone parting one out might be your best luck. I picked up front. N back of my chassis for 20 bucks.
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
01-22-2014, 10:40 AM | #5 |
I was looking for something new,I've seen someone use a use one before and everything sat weird
01-22-2014, 11:42 AM | #6 |
You can find the bushings but you need the cups washers and bolts? I don't see how that would make it sit weird if you used the cups it calls for. Early (73-80?)was different than late (81+) then they changed again in 84 or 5 for the parking brake cables. There are shims available for them too that a few trucks got too. I bet someone from the classifieds would have a rust free set they let go cheap...
01-22-2014, 04:06 PM | #7 |
Sorry I thought you meant use the old rubber as well, and thank you for the advise
01-22-2014, 11:21 PM | #8 |
I bought the kit from LMC. I think it was $170. I liked that it came with all the bolts and hardware and not just the rubbers.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
01-23-2014, 04:26 AM | #9 |
Depends, if you want sort of original with rubber, LMC is your best bet. For poly's (which I cosider being the best) you can go to Energy Suspension. I paid $60,- for the entire kit. Very happy with the poly's
