![]() Join Date: Sep 2013
What size pipe to use for upper RAD hose replacement
Want to get stainless pipe to replace upper RAD hose. I know I use 1 1/2 hose for upper but thats ID, right??
What size pipe should I get?? Thanks in advance. |
Re: What size pipe to use for upper RAD hose replacement
I used 1 1/2 and that's the same ID as your hose.
Just TIG welded it up from two 90 degree bends with a ring of 3/16 stainless filler rod for the lip to hold the elbows on. I get mine from : http://www.burnsstainless.com but JEGS, Summit, Vibrant has it as well. Silicon elbows from: http://www.siliconeintakes.com |
![]() Join Date: Nov 2001
be sure you put some sort of ridge or lip on each end if you make a pipe.
If your system builds up too much pressure, it could blow the rubber hose off the metal pipe.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
lookin gooooooood !!!!
I'm still trying to find someone local to make 1
What part of Houston? I'm about 1 1/2 hrs away, might be able to help you out.
-Sterling GIG EM' AGGIES!!!! WHOOOOOOP!!!!! "Whether you think you can or think you can't, you're Right." -Henry Ford 1972 chevy lwb 1934 ford p/u |
Ok so more like 2 1/2... I'm gonna make one for my truck this weekend ill pm you when it's done. Won't take 20 mins to do one with the orbital welder. Might be able to do 2
Ok lmk thanks !!
