![]() Join Date: Jan 2012
WTB: 60-66 Small Hump Rubber Floor Mat
Looking for a small hump rubber floor mat for my 65 C10. I've been working on my 65 restoration for nearly a year and this is the last part I need.
Re: WTB: 60-66 Small Hump Rubber Floor Mat
Hope you find a source, I've been looking for a couple years for a '64-66 small hump mat. Sounds like you're getting close to having it finished?
-John
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I am almost done. All that's left is to adjust the shift linkage and install the seat. Hoping to take it out for a test drive this weekend. I'll send you a few pictures.
![]() Join Date: Jun 2007
What am I missing here? Are the aftermarket companies not making the mats anymore?
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
Depending on where you call, you will hear one of two stories. Some places say it has been discontinued and the others say that the mold to make the mat broke and that once it is fixed they will begin making them again. The "mold is broken" story goes back to some time in 2012 so it seems doubtful they are going to fix it.
#6 | |
![]() Join Date: Aug 2013
yeah a 64-66 mat a few months back sold for $355 on ebay, i was able to snag an NOS 60-62 style its a different pattern, but its got 65' delivery date from Pittsburgh and it has the jute already attached. maybe you can find those yrs if your looking for a mat that fits and is of the same era...
#8 | |
Rollin' Old Skool
Did you try http://www.truckandcarshop.com/? You could also check with Tony at http://4-5-6chevytrucks.com/. Probably about a year & a half ago I checked with him when my dad was considering a replacement low hump mat for a truck he had. Tony had an NOS one at the time. My dad ended up cleaning the one he had since the truck wasn't really worthy of a nice one, & he was flipping it anyway. Some folks have reported issues with Tony, but I've bought from him on a couple occasions with no problem.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#10 | |
Not correct but. http://www.stockinteriors.com/molded...=31&ModelId=88
#12 | |
I'll be looking for a mat for my '64 low hump truck to . If anyone finds a replacement source
Thanks for the pictures. Looks like it turned out pretty good. I'm at the point that I will take just about any rubber mat that I can get.
#15 |
I came out good but far from perfect. PM sent
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
#16 |
65chevygal can you post pics of the repo mat ? I would like to see how they look. Thanks
#17 |
Here is a picture of the vinyl mat. My main issue with it other than it doesn't look original is that it's not cut to fit. You have to do a lot of trimming and cut out all of the holes. It's hard to make all of the cuts and make them look good. It's hard to tell in the picture but it looks worse close up and along the edges.
#18 | |
Also...if you can wait a few weeks, I'll be taking a nice one out of my 63 when I go to carpet. I'm in Fayetteville, NC.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#19 |
Still looking for an original mat, either an original in good shape or one of the reproductions from before the mold broke. If anyone has one or has any leads on where I might can find one I would appreciate it.
#20 |
all tucked away
#21 |
What style did Ford use for there small hump rubber floor mat? It might be identical and available. Worth a shot?
I would look up Ford 1961-66. |
#22 |
great idea, i think the are different
#23 |
Nice pimpston65, if you ever come across another one please let me know.
#24 |
if/when i find a 65 one i'll hook up with mine
