01-23-2014, 04:38 PM | #1 |
1965 Rear End Questions
My 1965 C10 Short Wheel Base truck has the original rear end. I am planning down the road to put a stronger LT1350 in the truck once its done.
My questions are this; I guess I will need to change the rear end to a posi rear end. Should I change the whole rear end or just the innards within my stock rear end? Do I just need to put in a better gear and posi or is that something I would need a whole new rear end to get? |
01-23-2014, 05:08 PM | #2 |
Re: 1965 Rear End Questions
You can get a posi unit for it and call it good. Or as long as you have the rear end torn down you might as well have it totally rebuilt. You might have to get a new ring and pinion set anyway so why not do it all.
66 shorty |
01-23-2014, 08:13 PM | #3 |
The factory diff is a 12 bolt and very capable of the power you'll put into it. If your going to put a posi into the diff, then spend the extra cash to replace bearing and seals which will save you a heartache later on. Good luck.
01-23-2014, 09:09 PM | #4 |
Thanks for the info. I'll just look I to rebuilding what I have with a posi unit.
01-23-2014, 10:41 PM | #5 |
Don't forget gearing.......
1936 Chevrolet 1/2t 1964 Chevrolet C10 1964 Chevrolet C10 (sons) 1965 Chevrolet K10 Suburban 1969 Chevrolet C10 1937 Plymouth P4 |
01-24-2014, 12:23 AM | #6 |
There is also this. http://www.summitracing.com/parts/pwt-1910-lr/overview/ Anyone know anything about them besides they make noise when you turn. Just want to know if they are reliable or not.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-24-2014, 11:28 AM | #7 | |
For sure.
Reading the link about them it says they cut down the noise. |
06-08-2016, 08:11 PM | #8 |
But Found Her 25yrs Later!
Anyone have recent experience with the PowerTrax?
06-08-2016, 08:48 PM | #9 |
I installed a Detroit TruTrac from Eaton and have zero complaints. Damn thing seems bomb proof so far and no clutch discs or springs to wear out.
You can check them out here. http://www.eaton.com/Eaton/ProductsS...trac/index.htm Easy to install yourself. |
06-08-2016, 09:12 PM | #10 |
Is the Detroit Truetrac something I can install myself?
06-08-2016, 09:15 PM | #11 |
Oops, I just re-read your post.
I see you posted "easy to install yourself"
06-08-2016, 09:21 PM | #12 |
Yeah I was concerned about doing it myself too but after talking with some differential shops I wasn't worried. You just need to make sure the shims and caps go back where they came from and don't mess with the pinion gear.
06-09-2016, 01:13 PM | #13 |
those lockers fit inside the stock carrier. take out your spider and axle gears and install the locker unit. You don't have to remove the carrier. I like the Spartan locker for ease of install. (u-tube has videos of install) some on e-bay for $260 with free shipping. I have never used one , but thinking about it.
1961 chevy K10 my build is------------61K10 build |
06-09-2016, 02:40 PM | #14 |
Yes, definitely looking for a unit I can install myself.
