01-25-2014, 02:33 AM | #1 |
Repop door hinges 55-59 reviews
Question has anyone used repop door hinges? Thanks in advance
1959 apache 1948 chevy coupe http://67-72chevytrucks.com/vboard/s...d.php?t=562949 1964 gmc burban build for pops http://67-72chevytrucks.com/vboard/s...d.php?t=724632 |
01-25-2014, 09:06 AM | #2 |
Re: Repop door hinges 55-59 reviews
I used them on mine, from LMC, I think. Fit and work. The doors are very smooth. Might get the same thing from the bushing kit, but for the cost, I wasn't willing to invest the time in that. Too many other things to do.
01-25-2014, 11:59 AM | #3 |
Nice thanks for the reply
01-25-2014, 04:09 PM | #4 |
Usually all you need is a hinge pin repair kit about $10 and half hour to fix them. stovebolts.com tech section shows the easy way (for and AD but TF is the same). And you know that they will fit the truck.
01-25-2014, 08:57 PM | #5 |
I don't know if there's ANYTHING I did on that truck that only took 1/2 hour. It might have started out that way........
01-26-2014, 09:42 PM | #6 |
I know what you mean, 1/2 hour assumes you have the hinges out of the truck, use a good hacksaw blade (Nickolsen are my choice), have the right size drill bit ready, drill charged, and all the parts assembled, and a press or big vice to press in the bushings. Before I found the tech article I had tried to drive the pins out to no avail....
01-26-2014, 04:25 PM | #7 |
i bought 4 for truk from lmc, fit and work great
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
01-26-2014, 04:29 PM | #8 |
+1 on the hinge kits. Unless your hinges are rotted out beyond repair (like one of mine was), just re-pin them. I was able to find a solid used hinge from a local truck yard. After putting new pins and bushings, good as new.
