Old 01-26-2014, 06:08 PM   #1
american revolution
american revolution's Avatar
80 blazer oil capacity
A little confused
Changed the oil and filter in my blazer added 5 quarts still oil stuck dry and no indication of oil in pan ?
Last time it was bone dry and I added 3 quarts so it might have had 8 quarts in the oil pan?
That doesn't seem right....everything is stock
Anything I should be checking?
american revolution is offline   Reply With Quote
Old 01-26-2014, 06:15 PM   #2
swissarmychainsaw
Re: 80 blazer oil capacity
What engine do you have in there?
Is is stock (might want to check the numbers on the casing).
Show some pics of your oil pan, and does it have an numbers on it?
Measure the length of your dipstick, with photos also, both in and out of the sleeve. Does it look stock to you?
If you put in 8 quarts does it THEN show on the Dipstick?
swissarmychainsaw is offline   Reply With Quote
Old 01-26-2014, 07:09 PM   #3
463
463's Avatar
5 quarts should put you on the stick for a V8,unless it's the wrong stick or a oversized oil pan.
Trueman
463 is offline   Reply With Quote
Old 01-26-2014, 11:03 PM   #4
american revolution
it's a 350 and looks 100% stock to me. even prior mechanics that worked on my blazer said it looks original.
i will take pics tomorrow.
what is the length of the oil dipstick on a stock 350? the stick looks newer that the engine....maybe previous owner switched out.
oil pan looks original...blu chevy color and I will take pics tomorrow.
when it had 8 quarts in it ...it finally showed on dipstick but thought that wasn't right so drained it...changed the filter...filled with 5 quart jug and it doesn't hit the stick.
Old 01-27-2014, 10:40 AM   #5
68Timber
I know the pieces fit
68Timber's Avatar
Sounds like the wrong dip stick.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-27-2014, 10:08 PM   #6
american revolution
here is a pic of dipstick.....think it is way short....also looks newer than the rest of the engine.
looks to measure around 21". anyone have a stock one to advise what size I need to be looking for?
Old 01-27-2014, 10:38 PM   #7
68Timber
68Timber's Avatar
I wish I could help but apparently can only add to the mystery. Here's the dip stick out of my 79, and it measures 18.5". Are you sure the pan is stock? I thought mine was all stock but now am wondering.
John
74 Honda Z50 build
Old 01-27-2014, 10:54 PM   #8
swissarmychainsaw
Which side does the 79 come on? Drivers?
Old 01-27-2014, 11:03 PM   #9
american revolution
its on the passenger side....jc whitney said they have an OE one for $16.00 he couldn't verify the size but said basically I can return full refund if it doesn't fit.
he was also checking something and he said they have 24" and 32" lengths also but he couldn't tell me where it was measuring from
the pan is original...5 quarts is the max right? i just changed oil and filter and put in 5 quart jug in it. the oil filter looks like it will take a quart by itself
thanks bruiser for checking.
Old 01-28-2014, 08:18 AM   #10
68Timber
68Timber's Avatar
Not a problem.
John
74 Honda Z50 build
Old 01-28-2014, 08:07 AM   #11
68Timber
68Timber's Avatar
Mine's on the driver's side.
John
74 Honda Z50 build
Old 01-27-2014, 10:53 PM   #12
swissarmychainsaw
I just looked around the web and it seems like there is not real clear answer.
Which side of the block is it on?
Looking for O'reilly replacements show 23" sticks, but they say "make sure it's the same length as the one you are replacing".
But that might be a start.
So this shows it will fit (passenger side) your year and make but it does not tell you the length:
http://www.summitracing.com/parts/lo...ions/year/1980
Old 01-31-2014, 06:33 AM   #13
american revolution
More to think about....guy has an oe dipstick on eBay for like $169.00 I asked him to measure and he emailed me back 23"
Old 02-03-2014, 07:03 PM   #14
american revolution
received the JC Whitney dipstick measured 23" and it worked...Problem solved...thanks everyone.
Old 02-03-2014, 09:53 PM   #15
lowrodderchev
lowrodderchev's Avatar
Maybe I'm wrong but how about the tube coming out if the engine maybe not in all the way or just a Chinese after market that's to long so it doesn't allow the stick to go all the way
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 02-04-2014, 01:15 AM   #16
american revolution
engine is 100% original...stick is correctly in the engine
