dumb question
is it possible to put the thermostat in upside down? before i put my intake on my heater worked and the temp stayed at 190 now it stays at about 130 or 160 at most, did i put the thermostat on upside down?? guess thats what ya get with a case a beer and a project sometimes haha
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck ![]() My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
Re: dumb question
I haven't tried, but you probably could. I would think that if it was upside down the metal element would be on the cool side and it would take longer to open and get hotter before it opened.
Mine wouldn't get hot because the PO took thermostat out... sure the thermostat isn't under the case of Bud? Anyway, if you are going to pull it out to check, you might want to drill a 1/8" hole in thermostat; I saw a bunch of posts on this and it did it.
1980 C10 Custom Deluxe, 250 L6, 3 in the tree. |
Re: dumb question
Case of beer for a thermostat?? You'll need a keg for a head gasket..
#4 | |
Re: dumb question
Re: dumb question
what does drilling a hole in the thermostat do? I've heard of people doing it but can't remember why
Re: dumb question
The hole helps prevent spikes in the temperature.
Re: dumb question
Re: dumb question
Ha ha. Sorry, I meant under the emergency backup case of beer.
I think the hole is supposed to ensure a little flow past the thermostat and also helps get rid of any air pocket which might slow down the thermostat response as well as the response of the other temperature switch and temp gauge inputs which are mounted at the top of the thermostat housing; you might see this more if you had drained the whole system like I had. Does it make a difference? Not sure, but some say yes, and it was fast and easy to do with little likely downside.
Re: dumb question
gotcha, i went a flipped it around, that sure was the problem, heats blowing real hot now buddy...still gotta figure out my other heat problem tho
Re: dumb question
no worrys haha...always have to have that backup case on standby haha
Robert Olson Transport
![]() Join Date: Oct 2002
Re: dumb question
just as long asyou didn't consume the case of beer THEN go for a test drive... that would be bad
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: dumb question
nah...lol...had to wait for the gasket maker to fully cure haha
#13 | |
Re: dumb question
I have always drilled the hole too, it does help.
The "old school" thing I was taught back in the day was to force it open and wedge it with an aspirin tablet. The theory is that it does the same thing as far as bleeding off the air, but then dissolves on contact with the coolant/water. I'm just not so sure that I want dissolved aspirin cruzing around in there?.....not a fan of forcing on the t-stat plate either....... an 1/8 to 3/16ish hole is much better. I have also heard of guys filling the system w/o the thermostat and housing installed, allowing the air out, then installing it when the coolant starts to come up in the manifold....seems like a pain to me?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() Last edited by LONGHAIR; 01-29-2014 at 06:11 PM. |
Re: dumb question
i think ill do that tomorrow after i figure out my defrost issue, i can't get the heat to come off the floor, going down the road tonight my windshield was freezing...not safe at all
#15 |
Re: dumb question
I think some of the thermostats for newer cars come with a small hole..
My truck would spike to 220* or so ..Then the t.stat would open and you could watch the needle fall on the temperature gauge. Two 1/8 holes and it just warms up to 180* and stays there. |
#16 |
Re: dumb question
Like everyone else is saying, it could be an air bubble. I was driving the '96 the other day after I replaced the thermostat and the temp shot up to like 260 with no heat... touched the top radiator hose and it was cold after running it for like 15 minutes...
Cooled the truck off popped the cap and cranked it back up again... 30 seconds later and bubbles started coming out. Added fluid as necessary and havent had a problem since.
Austin 1996 Chevrolet K1500 Silverado ![]() 1979 Chevrolet K10 Scottsdale - Carolina K10 - My 4.8L Twin turbo build - Project Short Stroke - Instagram - TheBlueBomber1996 |
#17 |
Re: dumb question
it turns out i put the thermostat in upside down, i flipped it and my heat started working...sorry about the late reply but i was trying to work other issues....as you can see in my other post haha...but i really appreciate the help..im gonna drill a hole in it tomorrow, i gotta clean my garage I've been super busy in there lately
#18 |
![]() Join Date: Jun 2010
Re: dumb question
What about installing something like this. You can get them from a vehicle at the junk yard or buy new. Just not sure if the housings on these trucks would be thick enough to drill and tap for it.
http://www.1aauto.com/1A/ThermostatH...FctcMgod9nYAUA
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#19 |
Re: dumb question
to put on the assembly over the thermostat?
#20 |
Re: dumb question
This is/was my thought. This pic is of an extra grand prix we have with the 3800 engine. Not saying it would work on these thermostat housing or not but I like the idea of them. I just got done redoing another grand prix last night and it makes bleeding the system a whole lot easier.
#21 |
Re: dumb question
I thought the reason the bleeder was on the thermostat housing was to bleed air from the highest point in the system. On some cars, the radiator inlet is located lower then the thermostat housing. Don't see a need for it on our trucks. It won't bleed the air from under the thermostat.
#22 | |
Re: dumb question
